Climate Control System Not Working - Mustang Evolution
Old 12-13-2004, 07:22 PM   #1
mach232's Avatar
Send a message via AIM to mach232
I just got off work a while ago and when i tried to turn on the heat nothing happened. i tried to cycle through all of the selections of heat/cooling, fan speed, and the position and nothing is working. is there anything i can do or check?
mach232 is offline   Reply With Quote
Old 12-13-2004, 11:32 PM   #2
I liek gramer
WhiteStang99's Avatar
fuses.
I'm not sure if those would be under the drivers side or in the engine bay.
Look in your owners manual at the fuse diagram. Pull any of the ones that have anything to do with heat, etc. I'm betting they're under the dash on the drivers side.
Just lay down in the drivers floorboard and look up.
Let us know how it goes.
Old 12-14-2004, 12:37 AM   #3
97Stallion's Avatar
Ya, it could be a fuse. Does it blow anything at all?
Living one day at a time!
Old 12-14-2004, 05:23 PM   #4
mach232's Avatar
no, nothing in the climate controls works or the radiator/engine fan doesnt work. i heard from somewhere the two are prolly connected so if the fan doesnt work then the climate controls wont work. the fuse im trying to get to is in the engine bay and its a Maxi size (the big one) except i cant pull it out. the fuse remover doesnt fit around it. should i try and replace the fuse (i got another one) or just take it somewhere to get it fixed.
Old 12-14-2004, 06:05 PM   #5
if you feel comfortable doing it... a shop will just yank it out with out care probably.... try to find a tool that will fit it....
Old 12-14-2004, 06:41 PM   #6
mach232's Avatar
yeah i removed the fuse and tried replacing it except the radiator fan and climate controls still dont work so its prolly something wrong with the wiring or whatever. im taking it down to the garage tomorrow to see whats wrong with it. thank you warranty lol
Old 12-14-2004, 07:11 PM   #7
97Stallion's Avatar
Ya, warrenties are the best, except when they nit-pick them.
Old 12-14-2004, 11:15 PM   #8
I liek gramer
i used pliers on one of my maxi fuses.
Old 12-15-2004, 07:17 PM   #9
mach232's Avatar
i read somewhere it might have something to do with the thermastat. i found that if i flushed the cooling system, it may get it to work. i know how to flush the system (thanks to the manual) but how do you drain the radiator and the coolant tank.
Old 12-15-2004, 07:33 PM   #10
steedav6builder's Avatar
Send a message via AIM to steedav6builder
you can just take the bottom hose off to drain the radiator and the overflow bottle comes off with 2 bolts. I would try unhooking the battery and leaving it unplugged for like 5 mins then hook it back up. i had the fan problem with my car because i needed to reset one of the sensors and that fixed it. easy to try.
-Gary Pics of my car
'99 Electric Green Cobra, #2517 of 4040 Built on 5/12/99
'00 Lazer Red V6-Gone but not forgotten
Central Jersey Mustangs and Fords Member #4121
Mid -Atlantic Cobra Association Member #207
steedav6builder is offline   Reply With Quote
Can you see it working? GhostStang 2005-2010 Mustang GT 13 07-13-2009 10:38 AM
charging system not working muskrat Classic Mustangs 8 04-12-2008 09:50 PM
Due to the climate of political correctness now pervading America Herbstang The Bar 11 01-09-2008 12:55 PM
working out... Tbird232ci The Bar 18 02-10-2005 02:54 PM
Working on a high power system but need insight....HELP A MAN OUT PLEASE?!!!! BlueThunder Mustang Audio & Video 1 10-15-2004 10:36 PM
01:01 AM
