4.2L, High Compression compared to Supercharger. - Mustang Evolution
Old 04-08-2009, 12:23 PM   #1
Renegade 800's Avatar
Region: Idaho
I was thinking about rebuilding to a 4.2 with high compression pistons, around 10:1 or 10.5:1. How will this compare to just adding a Blower without a rebuild? Cost wise I think it should be close to the same, about $5,000?
Renegade 800 is offline   Reply With Quote
Old 04-08-2009, 12:27 PM   #2
upton7's Avatar
Re: 4.2L, High Compression compared to Supercharger.
4.2 u need more cubic inches
Old 04-08-2009, 01:45 PM   #3
just putting a blower on will get you around 300rwhp if an auto a little less
a built 4.2 will get around the same probably~ but room to grow with good internals with a blower on top of it
Old 04-08-2009, 02:14 PM   #4
upton7's Avatar
^^^ exactly
Old 04-08-2009, 02:31 PM   #5
stangaroo's Avatar
There's definite pros and cons to each, I know that the rebuild of a 4.0 to a 4.3 with all forged internals and a big cam will get about 285 HP at the crank, however, this makes the block capable of about 550 HP if you decide to supercharge it later. All the parts are about $3500 plus installation.
The cons here are that your mileage will definitely go down whereas a supercharger will maintain your stock mileage under normal driving (if you can keep your foot from flooring it
stangaroo is offline   Reply With Quote
Old 04-08-2009, 04:34 PM   #6
RyansQuick6's Avatar
If you build a forged 4.3L (4.2 bored .030) properly, then you should have no issues hitting 650-700hp on F/I. Although for that kind of power, you;re gonna spend more on the engine and turbos than you did on the car.
You can slap an Eaton on your car for $2800 + boost gauge, programmer, and dyno time and have 300hp as well.
RyansQuick6 is offline   Reply With Quote
Old 04-08-2009, 04:38 PM   #7
stangaroo's Avatar
As it should be
Old 04-08-2009, 04:54 PM   #8
exactly
Old 04-09-2009, 11:11 AM   #9
runvsofthisbull's Avatar
One great thing about the ford blocks though is that they are strong as hell. Take Justin at Velocity Mustang's. He made ridiculous power on an all stock motor. I think it was 599 to the wheels! Obvioulsy he had a radical combination, however he used all stock internals and a stock top end. I agree that building up the bottom end would be wise, however just know that if you want some quick power and don't want the hassel of rebuilding the motor at this time, supercharge it as it will be safe at low-mid boost levels for daily driving. You can always rebuild it later and then just throw your supercharger back on and have the best of both worlds.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 04-10-2009, 10:45 AM   #10
stangaroo's Avatar
If the GT-R can safely squeeze 480 hp out of a 3.8 liter v6 then we're all in damn good shape, hah
Old 04-10-2009, 04:45 PM   #11
Please tell me you're joking about the Nissan Voided Warranty GT-R
Old 04-10-2009, 05:43 PM   #12
stangaroo's Avatar
wait, it doesn't come with a warranty? WHAT!?
Old 04-10-2009, 06:04 PM   #13
upton7's Avatar
is there a stroker kit for the 4.6?
Old 04-10-2009, 06:18 PM   #14
stangaroo's Avatar
yup, I don't know what the max is on it but I know there's a 5.0 and a 5.2 out there for it. It can probably go higher though, there's a stroker kit for the 4.7 magnum I had in my dakota sport that would take it to 5.5.
Old 04-10-2009, 07:38 PM   #15
upton7's Avatar
i found one for around 1and a half grand how much for installation u think?
Old 04-10-2009, 07:42 PM   #16
upton7's Avatar
or can you get one out of a ford truck or sumtin like that?
Old 04-10-2009, 08:01 PM   #17
stangaroo's Avatar
well a cam swap starts at a grand for installation and goes up of they need new rods and springs and all that, I imagine the stroker kit is more complicated than that...
There's a stroker kit to get the 4.0 block to a 4.2 using entirely ford parts from a truck engine, not sure if they have a setup like that for the GT though.
I also recently found out that the cast iron block in the 4.0 is much stronger than the aluminum one in the GT, so with all forget internals ($2500 bucks for everything including a big cam and stroker kit) you can handle way more boost than the v8 block can. YAY!
Old 04-11-2009, 10:37 AM   #18
OK there's a HUGE write up on this.
You basically take an 01+ block since they're the strongest, slap a 4.2 crank in it, 351/408 rods, bore it .030 over, use offset pistons and an 01+ oil pan. The rotating assembly alone can be had for less than $2k. Boring it .030 and slapping a 4.2 crank will give you a 4.3
There are some other things involved of course, but those are the biggest things.
Old 04-11-2009, 10:38 AM   #19
The warranty is voided if you do ANYTHING to the car, including unplugging the pcm or running the car on a dyno for any reason other than emissions testing
Old 04-11-2009, 10:36 PM   #20
stangaroo's Avatar
Yeah I googled this the other day, that car as a freaking lemon AND they screw you on the warranty...
1) running the car on a drag strip VOIDS THE WARRANTY!? WHAT THE HELL!
2) modding the computer (dynoing, tuning, ANYTHING) VOIDS THE WARRANTY!
3) TURNING OFF LAUNCH ASSIST THAT HAS A FREAKING BUTTON ON THE DASH FOR IT, VOIDS THE WARRANTY!?!?!?
worst car in the history of man kind. Well, it's bad *** for the first seek, but then it snaps the transmission in half, which isn't covered under warranty.
Old 04-11-2009, 11:01 PM   #21
an oil change at a Nissan dealer that is not an Authorized GT-R dealer voids your warranty
Old 04-14-2009, 08:33 AM   #22
SaleenFiend's Avatar
You don't really own the vehicle... it says it clearly in the paperwork.
Old 04-15-2009, 06:04 PM   #23
stangaroo's Avatar
Not Impressive Super Slow And Nasty
Non Pi to Pi compression iwannagofast 1996-2004 Mustang GT 12 12-30-2009 10:26 PM
2010 Camaro vs. 2009 Challenger SRT8 compared by proxy... how will new Mustang do? mlars General Car Discussion 4 08-28-2008 11:54 AM
Some opinions on High Compression and 4.2 w/ M90 builds needed Kiljosh Pre-2005 V6 Mustang 11 06-26-2007 12:01 PM
compression Js281GT 1996-2004 Mustang GT 17 01-10-2005 05:01 PM
GT-Take Offs Compared to name brands StangDoo98 Pre-2005 V6 Mustang 13 03-22-2004 07:22 AM
11:28 AM
