Rear suspension suggestions - Mustang Evolution
Old 12-17-2004, 08:49 AM   #1
Send a message via AIM to MustangMatt Send a message via Yahoo to MustangMatt
Question Rear suspension suggestions
All my suspension, front and rear is completely stock, except for 1" lower Eibach springs in front and rear, which came on the car when I bought it. My rear is really jumpy and skips alot around corners. My guess is that I need to replace the rear suspension. I'm looking to tighten up the rear strength. I was looking at Steeda Aluminum rear lower and upper arms. It would be nice to lose alot of weight in the rear, but tighten and beef it up. Suggestions please. Remember, that everything is stock and has NOT been replaced.
Thanks!
http://sunsap.home.mindspring.com/MMsiganimatior.gif
Currently stock; 5spd; Hurst T-handle shifter; 2pc. grille delete; 35%/20% tint
Planned Mods: 03/04 Cobra hood, rockers, front bumper (ordered!!), rear spoiler (ordered!!); Dark Charcoal Bullitts (18x9s and 18x10s); Bullitt 5spd pedals; more....
"I drive slowly when I run people over...." -Me
MustangMatt is offline   Reply With Quote
Old 12-17-2004, 03:39 PM   #2
dont get steeda, go with maximummotorsports.com they are far superior. That will help, if you want an amazing handeling rear end get a panhard bar with the lcas along with springs/shocks set up the same (what ever rate you want just get a handeling spring not just a soft rate spring that drops the car for looks only)
Old 12-17-2004, 04:58 PM   #3
SpectorV can you be a bit more specific on what type of springs and shocks I should get? I have Eibach 1" lower front and back springs.
Old 12-17-2004, 05:09 PM   #4
get tokico shock and your eibach springs are fine
Old 12-17-2004, 06:29 PM   #5
since you dont want a slamed car, your current springs may be perfectly fine, im not sure, i do know that the fms c springs/mach 1 springs/bullit springs are all very similar in rate. if your eibachs are 650front 250-300rear~ the mach 1 tokicos will work great with them.
a panhard bar is an amazing item, so are mm's lcas they are designed to prevent bind and make for less noise.
Old 12-17-2004, 07:45 PM   #6
97Stallion's Avatar
I would say your main problem is definately your shocks and struts. if you have wheel hop that bad, your shocks are not doing their job. They're there to combat your springs from creating the wheel hop that you speak of. I personally would go with a panhard bar yet, but that's up to you. I would focus on shocks and struts, sub frame connectors, a strut tower brace if you can get one. Lower control arms would help some also, but your car is rather new, so they can't be in that bad of shape.
Living one day at a time!
Old 12-19-2004, 11:27 PM   #7
fastmustangs1's Avatar
Thumbs up
The Panhard Bar and Torque Arm setup is the way to go, if you want that car to really handle. That is something I am going to install sometime in January. Right know I just have
Kenny Brown springs,strut tower brace,lower chassis brace
GRC Performance full legnth subframe connectors,
GT sway bars
Polyurethane bushings throughout
Maximum Motorsports lower control arms
Koni yellow single adjustable struts and shocks
Up next my Aluminum Rack bushings and Panhard Bar.
Matt
Name:	Matt Meredith (15).jpg
fastmustangs1 is offline   Reply With Quote
Old 12-20-2004, 12:13 AM   #8
Ponycarman's Avatar
Panhard rods are way too much $$$ from the aftermarket.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 12-20-2004, 12:25 AM   #9
ttpancakes's Avatar
Send a message via AIM to ttpancakes
I would have to agree with 232 just get the takico shocks and then you will be set.
ttpancakes is offline   Reply With Quote
Old 12-20-2004, 12:27 AM   #10
nah i d rather get tokicos
Old 12-20-2004, 12:32 AM   #11
ttpancakes's Avatar
So I make one mistake what give me a break i am tired
:hammer:
Old 12-20-2004, 10:20 AM   #12
I liek gramer
WhiteStang99's Avatar
Nah, I'd rather use punctuation.
Old 12-20-2004, 12:43 PM   #13
a panhard is 350-400 bucks from mm, they are alot but the difference they make in the car is amazing.
Old 12-20-2004, 01:51 PM   #14
:yank:
Old 12-20-2004, 02:00 PM   #15
the IntErnet dont use puncucatuation or spelllinz for tha mtrses
Old 12-20-2004, 03:05 PM   #16
I agree the PB are the way to go as far as handling goes since they control the amount of lateral movement in the axle. They are expensive but damn they
are worth it once you have it installed. That is next for me.
Matt
good rear suspension setup? notstock02gt 1979-1995 Mustang GT 6 05-01-2007 06:08 PM
Solid Rear Suspension Setup Thomas91169 1996-2004 Mustang GT 16 12-27-2006 01:51 PM
finally doin the rear suspension... Bane- Pictures and Videos 13 04-01-2006 12:02 PM
Rear Suspension problems BigL34461 Pre-2005 V6 Mustang 3 03-06-2006 01:58 PM
rear suspension need help fixing it... rpm Pre-2005 V6 Mustang 18 10-03-2005 07:01 PM
04:56 AM
