3.8 swap? 5sp vs Auto - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 12-18-2004, 05:06 PM   #1
mustbronc is unknown around these parts
1997.
I have purchased used 3.8 that was in a 1998 5 speed and want to put it in my 1997 automatic.
I would think the flywheel would need taken off the blown '97 automatic engine and put on the new/used 5speed engine?
Anything else? I have complete wire harness and all, so any suggestions would help,
Thanks,
mustbronc is offline
Old 12-18-2004, 05:22 PM   #2
Terminator Owner
SpectorV is just getting started.
i belive the auto and manual flywheels are different, but not sure.
SpectorV is offline
Old 12-18-2004, 07:13 PM   #3
SpectorV,
Thanks for the reply. Yes that is what my brother is telling me.
He also said i might have to change the harmonic balancer.....Oh well, guess i'll compare and learn as i go.
Thanks again,
Old 12-19-2004, 03:47 AM   #4
97Stallion's Avatar
97Stallion is unknown around these parts
no, you won't have to change the balancer, and the flywheel and flexplates are two different things.
Flexplate = Auto
Flywheel = 5spd
You'll need the 5spd computer or a chip or something to remove the auto tranny from the EEC
Living one day at a time!
DAMN Those are some old ass numbers!!! I need updated ones!!
97Stallion is offline
Old 12-30-2004, 10:34 AM   #5
Terminator Owner
its a major hassel.. its far better to sell the car and buy another one.
SpectorV is offline
Old 12-30-2004, 02:17 PM   #6
ttpancakes's Avatar
ttpancakes is unknown around these parts
Send a message via AIM to ttpancakes
That may be true, but where is the fun in that. It will probably take you a while but I would try and have it completed as well. What do you have more of, Time or Money?
ttpancakes is offline
Old 12-30-2004, 04:14 PM   #7
Js281GT is unknown around these parts
Plus it would be a good learning experience. You never know maybe you will like it & charge people to do it someday.
I have an 01GT w/ frpp 3:73's, sportline springs, wms cold-air w/95mm mass-air, (ceramic) BBK equal length headers (ceramic) mac 70mm t. body, trickflow intake plenium, mac pro-chamber, flowmaster catback, Nitto drags, NX N20 150hp jets, & some good predator tuning! Best E.T. 11.79 @ 118.4mph :drive:
[IMG]C:\Documents and Settings\jon.straszewski\Desktop\TOP ****y to bar 020.JPG[/IMG]
Js281GT is offline
Old 12-30-2004, 05:16 PM   #8
Dom
Dom's Avatar
Dom is unknown around these parts
Send a message via AIM to Dom
Well if you do it, be prepared to sitdown for a few weeks to do it.
Dom is offline
Old 11-30-2007, 03:43 PM   #9
fasst96 is unknown around these parts
Re: 3.8 swap? 5sp vs Auto
my mustang is a 1996 GT automatic i what to get a 5peed in it i got a clutch pedal out of a 2000 MUSTANG V6 will it work?... and what oder things to i have to get to do the auto to 5 speed manul swap. thanks
fasst96 is offline
Old 12-03-2007, 09:34 AM   #10
customsixstang is unknown around these parts
you will need the transmission obviously,flywheel,shifter and cables,which you may need the bushing and retainer clips for the shifter cable,brake/cluth pedal with a clutch cable possibly a cluth cable retainer,flywheel bolts,pressure plate bolts maybe transmission maybe but probably not. get some brake cleaner to clean off your pressure plate and your flywheel contact surfaces you gonna need a drill to drill through the fire wall for the cluth cable which you have to set thats up to you ever how you feel comfortable doing it. the auto tranny weighs alot you may need a friend to help you lift it or just drag it out the way w/e wow there still so much you have to do your best bet is to buy a engine and tranny combo just change your ecu and put a fuse you have a space for it you have to put in some fuses if you change it over. and just drill you hole for your cluth cable there so much more you have to do.make sure you when you take the flexplate off keep all bolts and but flywheel own it should only go one way so keep turning crankcase untill all bolts line up torque mine i did 70lbs but that up to you.make sure you get the speed sensor from the auto so your speedo wont be off. there so much else that i havent mentioned these are the basics you need someone to hold the clutch stable will you ut in the bolts for the pressure plate and flywheel connecting all the cable it will take you along time especially if you never done it i suggest you but a new engine and tranny and be done with it sell that used engine and auto tranny and say f*** it. trust you some guys say what the fun in that you will regret it if you do it it will take you alot of work to get everyting working properly with no leaks.smooth shifting etc and own a new cluth you need to drive it easy for atleast 500 miles to break it in. so its up to you ask if you need any help if you decie to do it.
customsixstang is offline
Closed Thread
auto to 5 speed swap help? mustangfan9969 Pre-2005 V6 Mustang 2 09-25-2009 05:02 PM
transmission swap (auto to manual) what parts? 6opka Pre-2005 V6 Mustang 8 04-02-2009 03:26 AM
06 gt auto to five speed swap. 06johnny 2005-2009 Mustang GT 4 07-13-2007 04:28 AM
what do i need to swap from auto to manual 97GtStang 1996-2004 Mustang GT 15 08-13-2004 08:09 AM
FS: 98 V6 Stang - 5sp v6mustangguy Mustang Parts for Sale and Wanted 2 02-04-2004 03:17 PM
03:48 AM
