Springs... - Mustang Evolution
Old 12-18-2004, 09:45 PM   #1
232stang01's Avatar
Send a message via AIM to 232stang01 Send a message via Yahoo to 232stang01
Question Springs...
I was wondering...
Wouldn't you realistically have to have an allignment done after changing out a set of springs?
232stang01 is offline   Reply With Quote
Old 12-19-2004, 12:22 AM   #2
yes, your camber, toe, and caster change
Old 12-19-2004, 09:57 AM   #3
Send a message via Yahoo to plstktnkr2
springs
I am thinking of getting Eibach springs and an energy suspention bushing kit, do I need a bumpsteer kit with these 2 upgrades?
[SIGPIC][/SIGP
1983 4 eyed GLX Convertible
1966 Lincoln Continental Convertible
1985 Lincoln Town Car Hearse
Local "10-hole Mafia" Don
member of the "Anti-Cowl" club
plstktnkr2 is offline   Reply With Quote
Old 12-19-2004, 12:12 PM   #4
Danger Dude's Avatar
Yes on the alignment and plstktnkr2 what amount of drop are you wanting depends on what you will need to do to the suspension. I personally thing all the bushing kits are a waste unless you are going to autocross or they have deteriorated
Old 12-19-2004, 12:15 PM   #5
he said he was going with eibach and i think the least you could drop with any eibach springs is like 1.5 inches
Old 12-19-2004, 01:14 PM   #6
Great which eibach's ????????? if you are at 1.5 and dont go to 2.0 you can get by with only C&C plates if you go past 2.0 the whole geometery is off and the need for additional steering and suspension components.
Old 12-19-2004, 01:21 PM   #7
prokit= 1.5 drop
sportline=2 drop
Old 12-19-2004, 01:46 PM   #8
springs
My kit will be Eibach pro kit and all my bushings are from '83 so its time to replace them
[SIGPIC][/SIGP
Old 12-19-2004, 01:47 PM   #9
Pro kit only requires C&C plates and Yes please replace your Bushings
Old 12-19-2004, 01:55 PM   #10
I will have to do some research on the springs to see if my front springs from Eibach Which are from a later car (V6) will fir my perches. Back are no problem since its a later 8.8
[SIGPIC][/SIGP
Old 12-19-2004, 03:01 PM   #11
232stang01's Avatar
so for a 1 1/2" drop I'd need C/C plates too? I'm trying to figure out exactly what I'd need.
Old 12-19-2004, 03:10 PM   #12
yes, i got my 1.5 drop and i need cc plates my aligment guy said my left side was .5 degrees off
Old 12-19-2004, 03:16 PM   #13
232stang01's Avatar
I guess nothing's gonna be a quick mod fix for me, cept for subframes. :arg:
Old 12-19-2004, 03:19 PM   #14
you could get camber wdges as a quick fix, thats what i did, till i get some cc plates by like next month
Old 12-19-2004, 03:20 PM   #15
232stang01's Avatar
elaborate? I'm a bit of a suspension tard...
Old 12-19-2004, 08:02 PM   #16
I would go with C&C plates if you drop 1.5. Dont waste time with wedges. they is just a rig job. It might be fine for a family sedan but not for a car you are trying to make a performance car !!!!
Old 12-19-2004, 08:10 PM   #17
exactly, the wedges i got are just a quick fix, till i can get some cc plates
Old 12-19-2004, 08:14 PM   #18
OH hell it was you that brought up the wedges again ARGGGGGGGGGGHHHHHHHHHHHH!!
Old 12-19-2004, 09:59 PM   #19
232stang01's Avatar
so I guess it's getting/installing springs (200$) allighnment (50$) and C/C Plates (200$)...
right?
any suggestions as to C/C plates? there's just so many out there...
Old 12-19-2004, 10:17 PM   #20
corey had told me to get upr cc plates
Old 12-19-2004, 10:21 PM   #21
The best C&C plates are either
MAXIMUM Motorsports at about 190.00
http://www.stangsuspension.com/store...?idproduct=164
UPR at about 140.00-160.00
http://www.uprproducts.com/shopping/...amber%2BPlates
Old 01-07-2005, 09:13 AM   #22
Send a message via MSN to RDS02Stang
I would say the best are those designed and built by Kenny Brown - they are not your fancy colorized aluminum but they are solid and easy to work with
Personally I would stay away from UPR - I literally HATE their customer service and most of their products are sub-standard.
:patriot: Robert :patriot:ATI Procharger StageIII, Ported Plenum, 75mm TB, Bassani X-Pipe, FlowMaster Cat-Backs, Kenny Brown Full blown extreme matrix subframe setup, Bilstein shocks & struts, and lot's more.
RDS02Stang is offline   Reply With Quote
Old 01-07-2005, 03:11 PM   #23
even wtih stock specs my tires wore bad... its just the specs stock use with wider tires.... i would eventually get mm cc plates just cuz they are so darn nice you can completely control how your tires wear
also there are two ways to install you can install for max camber or normal not really lowered car specs.
Old 01-07-2005, 04:23 PM   #24
They are a excellent product and I have had no problem with there customer service. I hit a piece of concrete in the road about a year ago it destroyed the Front left Strut, pushed the strut tower up 2 1/2 inches and destroyed the UPR C&C retention plate on the bottom side of the tower. I called them up and they sent a brand new set yet all I needed was the retention plate at no charge.
Customer service bad !!! NO.
I know a lot of drag racers who use UPR products and I will stand by their products. I am sorry if you have had problems but from all the people who use their products it appears to be a isolated incident.
Old 01-07-2005, 04:39 PM   #25
i would not go with their interior or what not accesorires but for everything else they are good.
Springs 1234 1996-2004 Mustang GT 4 04-10-2008 08:01 PM
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 04:57 PM
Cutting springs or Buying Springs Exit_In_Red Pre-2005 V6 Mustang 38 01-06-2005 01:13 AM
best springs oaktonarcher Pre-2005 V6 Mustang 10 06-11-2004 07:57 AM
which springs? Danger Dude Pre-2005 V6 Mustang 0 07-15-2003 01:10 PM
08:27 PM
