best performance for the buck?????? - Mustang Evolution
Old 12-21-2004, 12:13 AM   #1
i have a 2000 v6 stang i was just curious the best route to go, 1800 to blow current mods are headers and h back, 373s w/ t-lock. i want all motor i have a little idea of route but would like other opinions. thank you much
thinking pullies, cai, cam w/ rr, diablo, clutch(needed), 70mm tb, maby short shifter......... does a fly wheel really help that much??///
cjd10 is offline   Reply With Quote
Old 12-21-2004, 12:36 AM   #2
Well, I could use some Hans Race Craft sub frames, some Nitto DRs and street radials, um...I could prolly fill out the rest of your cash if you give me a bit.
Not sure about v6 mods, but, since you have 1800 to blow...then why not share the weath.
Old 12-21-2004, 12:41 AM   #3
lol. i do have 17x8 bullits w/ bfs 275 40s
Old 12-21-2004, 12:42 AM   #4
wanna trade
Old 12-21-2004, 07:37 AM   #5
You're on the right track:
Cold Air Intake (Get the bling versions, look better)
Clutch (Stage II minimum for longevity)
Instead of getting a 3.73 gears **and** a track lock for your 7.5 rear, and then paying installation, you can find a good 8.8 rear for about the same price on eBay. I paid $400 new for my 8.8. Sure, you may end up with 3.27 gears, but I made upgrade mistakes in the past that weren't buildable on other upgrades. Ended up selling off my old 7.5 (with 3.73 gears and track-loc) for about $200 resale...
70mm TB, don't waste your money. I'm pushing in excess of 420hp (w/o N20) and I'm using the stock TB with only the Half-Shaft mod.
Pullies - good choice
Short Shifter - Steeda Tri-Ax or the 5.0 Pro Shifter. I use the 5.0 Pro Shifter, have used the Tri-Ax, prefer the Pro Shifter.
Headers - You mention you have them, are the Long Tubes?
Nitrous - Squeeze the bottle. A 50-90 shot would be the kicker you'd have fun with. Use a wet system for installation ease. Limit your shot, and yhou won't have any problems. Your engine will handle it just fine.
Flywheel - I've used aluminum and steel ones, didn't notice a bit a of difference between either except the price. Waste of $$ IMHO.
Chip - Not really needed for your mods until you actually change your rear gears to keep the speedo correct. Performance wise, I did it early on and the only thing it did was decrease the performance of my wallet and make me have to run expensive premium fuel
Ignition Box, Spark Plugs and Wires - Stay stock, don't waste $$
Check The Ride Out... http://www.hpracing.net/mkonor.htm
Vortech SQ-2 w/2.62 pulley, Custom Stroked SSX 4.3l, G-Force T-5, SPEC 3 Clutch, Intercooler, CompuCar Nitrous Wet System, SVT Dual Fuel Pump/Tank, 42lb FMS Injectors, 90mm Lightning MAF, SCT Tuner Custom Setup by Velocity Mustang Perf, FMS 8.8 w/4.10 Gears, MAC Long Tube Headers
michael.konor is offline   Reply With Quote
Old 12-21-2004, 07:50 AM   #6
Danger Dude's Avatar
I agree with michael.konor on the list of mods. However unless you are going after mad crazy HP and you want to run slicks I would stay with the 7.5 and just put gears and a track lock in it unless you find a really good deal on a 8.8 rearend. Problem is that you dont know what you are getting with a used rear end and the Tlock could already be toast and the gears could be worn do to lack of scheduled maintenance and gear lube change.
Old 12-21-2004, 07:58 AM   #7
Just a matter of considering future upgrades. Overall, it only ended up costing me about $100 more to get an 8.8 setup than buying the stuff to setup a 7.5".
DD brings up a good point, I did find a good deal on a new 8.8 for a 99+ 8.8 rearend. Pre-99 rears are shorter and even though it'll work (especially if you swap your axles) stick with newer ones.
3.73 is a good ratio. I'm swapping out my 4.10's for 3.73's next week.
Old 12-21-2004, 08:59 AM   #8
How often should you have the gear lube changed?
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 12-21-2004, 09:04 AM   #9
I change mine every year, but I'm brutal on the drivetrain...
Old 12-21-2004, 09:08 AM   #10
With a tlok every 12 to 18 months. I changed mine exactly 14 months ago and just the other day as I was taken a sharp slow turn into a bank teller line I heard a slight moan from the rear end. Most people would not notice it but I am very keen on hearing changes in my car. Just remember to add friction modifier every time you change the rear end lube. If you have someone else do it make go by Ford and pick some up it is cheap then take it with you to give to the shop so they put it in !!!
Old 12-21-2004, 09:32 AM   #11
how do you change it?
-Denver
Old 12-21-2004, 09:58 AM   #12
Monkey's Avatar
open the diff cover and let it drain out, then put oil in the fill plug on the top of the case.
I know you said you wanna go all motor, but nitrous is THE best bang for your buck. PERIOD. Where else can you get 100rwhp for $400? All those things you listed (cai, pulleys, cam, heads, etc) wont even get you 100rwhp... not even close. And it will cost 4x what nitrous costs.
If your heart is truely set on N/A, then get a new cam and new heads and roller rockers, a clutch, resurface the flywheel, and get it dynotuned. Should add about 40rwhp for you.
Old 12-21-2004, 11:56 AM   #13
sorry guys miss understanding i already have the tlok and 373's.. the headers are short tube wanted long but got a great deal. any suggestions from where to get a clutch??
Old 12-21-2004, 11:58 AM   #14
im considering nos but how much is a truly safe shot??
Old 12-21-2004, 12:02 PM   #15
Wet shot 50-75 shot safe without tune though at 75 I would recommend a tune, 100 shot with chip or dyno tuning
Dry shot I would tune no matter what
Old 12-21-2004, 12:09 PM   #16
thank you for every ones help..
Old 12-21-2004, 12:31 PM   #17
Directly from SPEC is easy. www.specclutch.com
I'm running a SPEC Stage III and their billet steel flywheel.
Old 12-21-2004, 10:26 PM   #18
Monkey's Avatar
http://mustangevolution.com/forum/showthread.php?t=6094
Old 12-21-2004, 10:32 PM   #19
isnt it better for splitport cars to get dry nitrous kits
becausethe wet kits can cause puddles in the manifold and cause some damage
Old 12-21-2004, 11:04 PM   #20
Monkey's Avatar
no. dry kits are worse on split port because of the returnless fuel system
Old 12-21-2004, 11:05 PM   #21
thanks for clearing that up god :thumbs2:
Old 12-22-2004, 01:06 AM   #22
THANK YOU BRANDON great article for this conversation very informative i do apreciate it. :beer:
Old 12-22-2004, 10:36 AM   #23
Monkey's Avatar
:thumbs2: That's what I'm here for.
Oh, and if you decide to go with nitrous, lemme know, and I'll help you install it since you're here in Dallas somewhere. (I'm in Arlington, but spend my time b/w there and Plano)
Old 12-22-2004, 02:18 PM   #24
thatll work i like in carrollton more or less right on the boarder... i will be sure to let you know though thanks :phat:
Best bang for buck 100stanggt 1996-2004 Mustang GT 13 05-30-2010 10:02 PM
Best Bang for the buck?? Scorpion1 Pre-2005 V6 Mustang 7 09-26-2008 10:45 PM
best bang for buck mustang0386 Pre-2005 V6 Mustang 7 11-13-2006 01:08 PM
best bang for your buck SC kits? Thomas91169 1996-2004 Mustang GT 19 09-23-2006 12:11 AM
My dad got a buck yesterday. MusclesFromBrussels The Bar 23 11-15-2003 10:51 PM
» Members Mustangs
Todd
tjzola
Ariel
JSHOOT3
Add your Mustang
06:18 PM
