Ignition Lock problem - Mustang Evolution
Old 12-28-2004, 10:24 AM   #1
BlueDonkey's Avatar
Yesterday I encountered a problem with my ignition lock; it won't turn. In either direction. Does anyone have any ideas/suggestions?
BlueDonkey is offline   Reply With Quote
Old 12-28-2004, 11:25 AM   #2
I liek gramer
WhiteStang99's Avatar
stupid idea, but did you try to move the wheel and then turn the ignition?
Old 12-28-2004, 11:48 AM   #3
BlueDonkey's Avatar
yup. tried that. tried it too much and locked the steering wheel in place
also tried
- lightly tapping the key in to make sure it was all the way in
- warming the area around the lock to see if I got some frozen water in there
- WD-40 on the key, inserting the key into the cylinder repeatedly
Old 12-28-2004, 12:08 PM   #4
I liek gramer
sorry man, can't help ya there...
I was sure you had tried that with the wheel, but I just wanted to make sure. A couple times I know my wheel has kept me from turning the ignition and it usually gets me for a few seconds everytime.
Old 12-28-2004, 01:58 PM   #5
Send a message via AIM to NJStang86
This probably sounds really stupid, but try pushing in the brake while u turn the key. Also make sure the car is in Park and not in gear.
You're probably going to have to give it a real good turn (use dem muscles). It's happened to me once before and I just had to turn it real hard.
Good Luck!
-Frank-
http://home.earthlink.net/~riz3742/sig2.jpg
2003 Ford Mustang Dark Shadow Gray Coupe - 15.616 @ 87.24 (work in progress)
NJStang86 is offline   Reply With Quote
Old 12-28-2004, 02:05 PM   #6
BlueDonkey's Avatar
Good Luck!
it's a manual; I'll try neutral.
Old 12-28-2004, 06:12 PM   #7
on my manual sometimes I have to turn the wheel and hold it a bit to get the key to move, try holding it not just wiggling it, and what not, check the little button to release the key also.
Old 12-28-2004, 09:42 PM   #8
BlueDonkey's Avatar
tried neutral, in gear, brake on and off, with the key release pushed and not pushed. I don't know if I can implement holding the wheel; it's locked in place.
Old 12-28-2004, 09:52 PM   #9
Dom
Dom's Avatar
Send a message via AIM to Dom
Turn the wheel really hard to the right I think. To the point where you feel you might break something. Mine does it some of the time.
Old 12-29-2004, 07:26 PM   #10
the mustang is bad about this issue.
Old 12-31-2004, 08:25 AM   #11
BlueDonkey's Avatar
Ignition lock cylinder replaced, problem fixed. Thanks for your help, guys.
Old 12-31-2004, 05:43 PM   #12
glad its fixed
95 mustang wont start, ignition problem? Billy95Gt 1979-1995 Mustang GT 5 07-29-2010 09:03 PM
ignition problem on 94 5.0 matts94gt 1979-1995 Mustang GT 7 05-16-2010 02:04 PM
Ignition lock cylinder Babydoll General Mustang Discussion 5 01-05-2009 04:51 AM
Power window and lock problem need help blzfan1963 Pre-2005 V6 Mustang 3 08-08-2008 06:35 AM
09:12 PM
