Got a pinion seal leak... - Mustang Evolution
Old 12-29-2004, 08:25 PM   #1
found it today, any ideas on how much it should run, talked to a guy I know at ford, said an hour of labor plus the seal... so not to bad from the sound of that.
Old 12-29-2004, 09:25 PM   #2
this is the seal where the driveshaft meets the differential right? if so, replace it yourself its not a hard task.
Old 12-31-2004, 12:39 AM   #3
so any update on this did u replace it?
Old 12-31-2004, 12:51 AM   #4
gonna go early next week or the next and get her fixed....
Old 12-31-2004, 12:56 AM   #5
your gonna do the job yourself right?
Old 12-31-2004, 06:43 PM   #6
im gonna get my friend sam to help this way I can help do it but wont screw up
Old 01-03-2005, 09:32 AM   #7
havn't you had rear end problems before? or was that someone else...
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 01-03-2005, 01:39 PM   #8
i think i remember him saying he broke his t-lok
Old 01-03-2005, 03:06 PM   #9
ive broke all kinds of stuff in my rear end this however was just wear and tear probably.... i dont abuse my car or have i been to the track or anything just something thats happend, im listening for any noises for a low fluid sign, nothing yet i think it will be fine till next week but its getting fixed then.
Old 01-03-2005, 03:19 PM   #10
Ponycarman's Avatar
The 8.8 rear used a crush spacer to set pinion bearing preload. The correct way to replace a pinon seal is to replace the crush sleeve too. You have to torque the pinion nut down to several hundred foot pounds and measure preaload, then keep torqing the pinion nut down till you reach the preload spec, too far and you get to do it all over again with a new crush sleeve.
I doubt you got the tools to do it. This might be a case of letting the dealer do it is a good idea.
Or you can replace the crush sleeve with a solid spacer and shims.
http://www.ratechmfg.com/fordspbs.htm
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 01-03-2005, 03:59 PM   #11
the guy thats helping me works at ford, so we will be doing it there with his tools i wouldnt do this in my driveway to much hassel and tqing it down would be a major pita.
Old 01-03-2005, 06:24 PM   #12
I liek gramer
WhiteStang99's Avatar
Old 01-03-2005, 06:27 PM   #13
if you have a lift., torquing= no problem
Old 01-03-2005, 10:03 PM   #14
Ponycarman's Avatar
If you don't have spaghetti arms then 200+ ft/lbs of torque isn't tough.
This is definately one job where having the right tools is a virtual requirement.
Steve
1996 Mustang
1965 Barracuda
Old 01-03-2005, 10:54 PM   #15
yup
Old 01-03-2005, 10:55 PM   #16
i can do 200 ftlbs no problem lol i should have got a pic of brent trying to break a bolt loose when we were installing his s/s lol
Old 01-04-2005, 08:23 PM   #17
Ponycarman's Avatar
So, is Brent's new nickname Spaghetti Arms?
1996 Mustang
1965 Barracuda
Old 01-04-2005, 09:04 PM   #18
lol
Old 01-04-2005, 09:19 PM   #19
:chin:
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-28-2008 12:54 AM
New U.S. Seal Herbstang The Bar 8 08-07-2008 01:59 PM
'98 Marker Light seal? matthews.stang Mustang Audio & Video 4 05-26-2007 12:18 AM
Tail light seal? 19ClearCobra96 Mustang Audio & Video 13 03-27-2005 09:24 AM
Pinion seal now fixed SpectorV Pre-2005 V6 Mustang 2 01-11-2005 08:19 PM
03:46 PM
