Auto transmission problems. - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 04-16-2009, 10:24 PM   #1
6opka is unknown around these parts
ok, my 1996 v6 mustang was experiencing some difficulties with the gear box. it all started like this:
i was driving up a big hill, when i reached a traffic light i noticed white smoke coming from the sides of the car (the wheel arches). i popped the hood to find the smoke steaming from the passenger side of the engine compartment where the exhaust headers are and red gear oil was spilling on the ground from the cat converter or around it (didnt see very well).. in any case i drove home and the gear box died on the way. i think it did..
i have one guess only to what could have happend: i have a trans oil cooler. the lines of oil leading to the radiator could have rusted or just brake off somewhere.. what else could lead to what i described?
6opka is offline
Old 04-17-2009, 06:27 AM   #2
SaleenFiend's Avatar
SaleenFiend is unknown around these parts
Re: Auto transmission problems.
Yes, sounds like you have a busted transmission cooler line. You need to get under the vehicle and check where the leak is coming from. The white smoke (as you said) is coming from the fluid hitting the exhaust. Your probably out of fluid which doesn't let the transmission pressure up. You should be able to put it into any gear on the selector but it won't do anything right? Top off the fluid and fix the leak. If the transmission continues to work that solved all of your problems, but depending on how low the fluid got it may have blew the trans. If you need help looking for one I'm sure you could use
SVTPerformance.com or even PM me, Darkshadows, or iamdat (on this website) to get help pricing a new transmission or cooler lines.
SaleenFiend is offline
Old 04-17-2009, 11:51 PM   #3
Hope i didnt blew it, i did ride with low oil.
6opka is offline
Old 04-18-2009, 04:13 AM   #4
sledgehammer's Avatar
sledgehammer is unknown around these parts
Send a message via Yahoo to sledgehammer
must have been the drifting!
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline
Old 04-18-2009, 02:38 PM   #5
Do you have any other word on what happened? New Symptoms?
Closed Thread
94 Auto Transmission winterwolf Pre-2005 V6 Mustang 4 01-23-2010 12:40 PM
transmission swap (auto to manual) what parts? 6opka Pre-2005 V6 Mustang 8 04-02-2009 03:26 AM
02 Mustang Possible Transmission Problems TK225 General Mustang Discussion 3 10-07-2008 06:41 AM
95 3.8 V-6 Engine & Auto Transmission teddy44 Mustang Parts for Sale and Wanted 1 12-06-2004 11:36 PM
Problems with my Auto.... Brent Pre-2005 V6 Mustang 20 07-26-2003 10:41 AM
03:54 PM
