got springs, now what? - Mustang Evolution
Old 07-30-2003, 02:36 PM   #1
Send a message via AIM to sp33d
ok, i got my springs. maxspeed w/ a 2'' drop...
... my question for you guys: what else do i need?
over at v6power ive heard you need cc plates. do i really need aftermarket cc plates or would it just be *better* to have? also, ive heard people say i need new shocks and struts. do i?
is there anything else i might need?
i dont wanna install the springs myself cause i work 6 days out of the week, and i just dont trust myself, plus i dont even have jack stands or ramps yet... so where should i get them installed? would i need to goto a custom car shop or does like autozone or someone like that install aftermarket springs?
thanks guys
sp33d is offline   Reply With Quote
Old 07-30-2003, 02:40 PM   #2
Danger Dude's Avatar
anything over 1.5 drop is going to reqiure C&C plates period. You dont have to get new shocks but I would suggest you get them to improve handling. You would not spend 1000 on rims and then put old worn out tire on them would you
Old 07-30-2003, 06:38 PM   #3
Send a message via AIM to slow232 Send a message via Yahoo to slow232
Yes with that kinda drop you will need cc plates,It wouldn't be a bad idea to get Shocks and struts.Also if you dont have the tools to install them yourself well then your going to throw away 200 bucks for instalation.I say you go out and buy some tools if your gunna continue to mod your car.
Not to sound like a #### but why would you buy some POS springs? ever hear of spring sag? well i gurrante your going to get to know spring sag rarther quick.
slow232 is offline   Reply With Quote
Old 07-30-2003, 10:07 PM   #4
Rick0636's Avatar
I hate to say this, but I will anyway, I had 2" drop Jamex springs on my 94 Vert, I had to end up buying Steeda rear springs for it, and then I put two sets of Kenny Brown spring spacers under the front springs, it was still sort of low in the front. Yes, you are going to need C/C plates, I have Steeda Sport front springs now, and I still plan to get them eventually. Btw, that is 1.25 in drop, I am now using the old Jamex rear springs on my GT with 7/8" Global West spring perch spacers on my aftermarket control arms to keep them from being so low. I may yet get Steeda rear springs because the things are sort of low and kind of stiff with those spacers under them too. You should have gone with a Ford spring or a name brand aftermarket really.
Old 07-30-2003, 10:56 PM   #5
tire's Avatar
Send a message via AIM to tire
you can always install two springs on a day and do the other two later on.
get spring isolators, about 20 bucks for rear and 20 for the front ones.
otherwise you'll get squeeking and it'll annoy you to no end.
why a 2" drop, going for slammed look?
tire is offline   Reply With Quote
Old 07-30-2003, 11:12 PM   #6
Rick0636's Avatar
I have never done a rear spring install, mainly because I had those installed the same time as control arms, which I didnt' think I wanted to try in the back yard. So I just let them do the rear springs while they were at it, front springs aren't so bad.
Old 07-30-2003, 11:15 PM   #7
Rick0636's Avatar
I tell ya what, if your springs are anything like the Jamex were on my 94, you will be in for some treats, lol. Nothing like dragging the bottom of your car on the pavement at 60mph when you hit a dip in the road. I wore out that rubber pinion snubber it rubbed so much. And this is one that came with the springs...
Old 07-30-2003, 11:19 PM   #8
tire's Avatar
rick,
would cutting the stock bumpstop down some work as well? isn't the stock one fatter and longer, so that it would have more surface area than the aftermarket one?
Old 07-30-2003, 11:28 PM   #9
Rick0636's Avatar
It probably would, yeah. I don't think we did anything with the pinion scrubber on the GT at all, and I have never heard it rubbing like the one on the V6 did, but then its got those 7/8" spacers under the Jamex rear springs now too, lol. That rear end is so stiff I can't even make it go down at all hardly, and I weigh in at about 250.
Old 07-31-2003, 02:42 AM   #10
tire's Avatar
spacers = isolators or something?
Old 07-31-2003, 03:04 PM   #11
i got the 2'' drop cause i wanted to get rid of wheel gap. as for maxspeed, i know people that have used their products in the past and havent heard any problems. theres also a guy over at mustangworld with the springs and i asked him about them, and he said basically the car isnt as comfortible, but handling is way better, and i really like the way the car sits with a 2''. i guess its just preference... but then again i cant really speed down the highway anymore, and i'll probly be backing into my driveway from now on...
as for cc plates, what kinda works best? where should i get them?
Old 07-31-2003, 04:39 PM   #12
you can have a shot set it so you wont need CC plates they can alter the stock parts so you can adjust them how ever you want wiht out need of new cc plates. with a 2 inch drop you definatly will need more than stock adjustmetn will allow.
Old 07-31-2003, 06:24 PM   #13
tire's Avatar
i don't know if anyone has said shorter endlinks, but you need them they'll help a lot.
www.maximummotorsports.com
go to their online store and find the endlinks for "1.5+" drop mustangs"
15 bucks or so. it lowers the front sway bar parallel to the ground so as to provide better handling.
Old 08-01-2003, 03:06 PM   #14
I have not found the end links coudl ypu post a better link?
Old 08-01-2003, 04:06 PM   #15
Get your head out of your ***.
http://www.maximummotorsports.com/urethane_front.asp
Old 08-01-2003, 07:44 PM   #16
Rick0636's Avatar
No, spacers don't equal anything but spacers, what I have are spring perch spacers from Global West http://www.globalwest.net/mustang%2079-98.htm#Rear%20spring%20perch%20spacers Check them out there. They were designed to compensate for one spring that has sagged, but can also be used to raise springs that are too low which is what I did with the 2" drop Jamex rear springs I have on the GT.
Springs 1234 1996-2004 Mustang GT 4 04-10-2008 07:01 PM
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 03:57 PM
Cutting springs or Buying Springs Exit_In_Red Pre-2005 V6 Mustang 38 01-06-2005 12:13 AM
best springs oaktonarcher Pre-2005 V6 Mustang 10 06-11-2004 06:57 AM
which springs? Danger Dude Pre-2005 V6 Mustang 0 07-15-2003 12:10 PM
02:42 PM
