97 Stang Auto Trans Problem - Mustang Evolution
Old 04-19-2009, 12:15 PM   #1
Question 97 Stang Auto Trans Problem
I pulled my 97 mustang into my driveway and put it in park then went back put it in reverse backed out and now it's stuck in reverse and won't come out it has an auto trans any ideas as to what might be wrong with it? any input would be great thx,Stealth
Stealth is offline   Reply With Quote
Old 04-19-2009, 01:49 PM   #2
MonteCitan's Avatar
Re: 97 Stang Auto Trans Problem
First, does the shifter still feel like it's clicking into the slots? (like you can feel a 'notch' when you put the car into reverse, then into park, reverse to neutral, etc)
I'm going to guess it's either in the shifter, the trans range sensor, or any combination of the linkages in between..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 04-19-2009, 03:20 PM   #3
well after it got stuck in reverse i pulled the trans out but when you pull the shifter cable it feels like it's goin into notches and the trans was perfect until it got stuck in reverse where is the trans range sensor located at ? i don't that much about transmissions but i'm trying to figure out what could be wrong with it any help would be great thx,Stealth
Old 04-20-2009, 12:19 AM   #4
MonteCitan's Avatar
So the car is not stuck in reverse, but the shifter was? I must have misread your first post, I apologize - Not sure what would cause it to get stuck in reverse if it's the shifter- as you shouldn't have to press the shift release to get it from reverse to neutral.. It would make more sense if it got stuck in park..
Hopefully someone else will chime in with some personal experience or better ideas
Old 04-20-2009, 12:37 AM   #5
Even knowing the prob you won't be able to fix it,:dunno: the mechanic will....:whistle:
BigDaddys S is offline   Reply With Quote
Old 04-20-2009, 07:10 AM   #6
ok let me make the problem a little more simple to understand
pulled into my driveway put the car in park
got ready to back out put the car in reverse and i backed out
then when i put the car in drive it was still in reverse
put the car in 1st and it was still in reverse
put the car in 2nd and it was still in reverse
put the car in neutral and it was still in reverse
put the car in park and it was still in reverse
so the problem is the trans itself is not changing from reverse to drive,1st,2nd,etc
which is why i'm thinking it's a sensor
it has some sort of sensor where the shifter cable is hooked to the trans it's a black box with a plug on it
and as i've said before the trans was perfect until it would not come out of reverse the shifter worked perfect in it maybe this will help clear things up abit
Weird trans problem, help! fast64 Pre-2005 V6 Mustang 1 11-28-2009 01:31 PM
99 GT Auto Trans Problem hawks05 1996-2004 Mustang GT 2 02-24-2009 04:50 PM
00 gt auto trans issues cue59 1996-2004 Mustang GT 9 02-17-2009 04:12 PM
v6 and v8 auto trans mustangmichael 1996-2004 Mustang GT 4 09-19-2006 07:17 PM
3.8 EFI V6 and auto trans... BK Meyers Mustang Parts for Sale and Wanted 0 07-11-2004 07:27 AM
10:34 AM
