Powering both fogs from..... - Mustang Evolution
Old 01-03-2005, 04:16 PM   #1
the power wire on the amber parking lights, so far so good, I used to have a relay that turned on via that wire but it no longer works.... so Im using this with a fuse of course
sound ok?
Old 01-03-2005, 05:55 PM   #2
The fog bulbs pull 2-3 amps each, I would run each fog off each headlight bulb wire if I was going to do that. If you have a wiring harness from us we can send you a new relay.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 01-03-2005, 06:15 PM   #3
its cool, i can pick up another relay np just wondering before i worked on it any more, so far the head lights and fogs are just as bright as they ever have been... im goign to keep an eye on it and most likly put a relay in regardless.
Old 01-03-2005, 06:17 PM   #4
I liek gramer
WhiteStang99's Avatar
so you got them fixed? lol
Old 01-03-2005, 06:42 PM   #5
yea one went out it was the harness nothing else.... the stupid end hardness came loose a bit, didnt take to long to fix, i just went ahead and revamped everything.
Old 01-18-2005, 11:26 AM   #6
Bane-'s Avatar
in a perfect world...all you really had to do is run ur wires from ur fogs to the headlight hot wire, and just put a inline fuse in there somewhere...correct?
just did this for the 88 with reverse lights, guy didnt buy the $16 part to have reverse lights with the b&m shifter, ran a toggle switch to a inline fuse, to a round metal end peice (like the round battery terminal connecter things) into the fuse panel, then to the reverse light bulbs. was pretty proud of myself considering I hate anything to do with eelctrical ****. and you can only see 4" of the wire, but that will be cover when i make my rear seat delete.
Old 01-18-2005, 02:34 PM   #7
He wants to be able to cut on his fogs without having his headlights on
Old 01-18-2005, 04:18 PM   #8
I liek gramer
can't you buy an OEM switch...?
Old 01-18-2005, 05:11 PM   #9
Mjcorn23's Avatar
You should be able to get one look into places like 5.0 resto but unless you know how to do the wiring I would have someone else do it
2002 Laser Red V6 mustang
"Six Shooter"
15.7@93mph lots of wheel spin
Mustang anything else is just a wanna be
http://i16.photobucket.com/albums/b9...n123/corn2.gif
Mjcorn23 is offline   Reply With Quote
Old 01-18-2005, 08:49 PM   #10
It comes with the kit from Velocity, but you still have to wire it through somewhere to get power, and one of the easiest spots to tap into would be the parking light's wire.
Old 01-18-2005, 08:54 PM   #11
slvr2000stang's Avatar
Mount the relay next to the high current fuse panel under the hood.
You have a +12v distribution right there.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 01-18-2005, 09:05 PM   #12
Bane-'s Avatar
yea use the parking light wire then, fogs fore my truck are like that, cant turn them on by themselves need atleast parking lights to be on.
Old 01-22-2005, 06:40 PM   #13
i want the fogs to come on when ever the parking lights are ok, and yes you can run it off the power wire for the fogs, but a relay is a better idea due to it pulls power directly from teh battery and uses the power wire for the head lights as an on "trigger"
New Software Powering Mustangevolution.com Brent ME Site Help & Announcements 3 08-18-2006 05:17 PM
fogs installed **pics** BirminghamStang Pictures and Videos 4 08-06-2006 08:48 AM
Pictures of the new fogs 232stang01 Pictures and Videos 19 01-23-2005 11:08 PM
fogs? cuban3jumper Mustang Audio & Video 1 06-22-2004 09:53 PM
Will 95 fogs fit? SixshootaPB Mustang Audio & Video 1 08-18-2003 10:58 PM
01:57 AM
