Bad news help please!!!! - Mustang Evolution
Old 04-21-2009, 07:05 AM   #1
kack85's Avatar
Region: West Virgina
Exclamation Bad news help please!!!!
I snapped a bolt removing the head and took it some so called shop but the screwed me... they tried to drill it down and put a start bit in it and tried to turn it with rachet, guess what start bit broke and after about 10 minutes off watchin the get no where i grabbed my head and left... problem is I can seems to drill the star bit out the stuck in my broken bolt to use an easy out and i notice they tried to weld i guess the bit back together, I dont know but i need some help... I'm kicking myself in the *** big time.... by the way its not a head bolt its an lower intake bolt into my head sorry bout that....
Any tips on how to get it out... Also how much maybe a junkyard head run for and what year should I get maybe i can gain some hp with gettin a newer 3.8l head....
Can i just put the heads back on and over torgue the intake, and put some rtv sealant... I dont think I can just askin doubt i would get a hole oil change or even a start up without a leak....
I REALLY THANK ALL FOR HELP!!!
94 mustang 3.8lll
94 Mustang 3.8L v6 Project Black Out... Lookin to rebuilt, add some +HP, and let the stang to its thang....
kack85 is offline   Reply With Quote
Old 04-21-2009, 09:13 AM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: Bad news help please!!!!
94 mustang 3.8lll
always a bad idea to over torque something... think about swapping to the 99+ heads and intake
Old 04-21-2009, 10:04 AM   #3
hottcobra's Avatar
all you can do now is drill out everything from the hole and put a heli-coil in it's place. It's gonna be tuff to drill. you really need a drill press to do it right.
Old 04-21-2009, 11:28 AM   #4
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
I did that with the upper intake bolt thinking tighter was better. snapped off like a twig. I just left it like that...
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 04-21-2009, 06:11 PM   #5
Region: Iowa
the engineers that designed the motors decided on a torque spec... but if you think you're smarter off than them, feel free to over torque what they recommend. Afterall, they designed it for that spec
Old 04-25-2009, 06:51 AM   #6
kack85's Avatar
Thanks guys I'm not gonna over torgue it thought bout it might last for week if that but will leak and have to re-do it again... I went and got it drilled out and put a heli coil in it....
Old 05-04-2009, 06:08 PM   #7
BIGBLOCKTRADER's Avatar
heat the bolt with a propaine torch. get it good and hot. slowley.take some wax like a candle. put it on the hot bolt and let it melt in.let it cool completely.smack the center of bolt with center punch.this will loosen bolt in its theads. some times u can then turn it by hand or a left hand bit
BIGBLOCKTRADER is offline   Reply With Quote
Old 05-04-2009, 08:41 PM   #8
Cobra GT's Avatar
I have used my Fordom flexible shaft grinder w/ a carbide bur on exhaust studs to get that hard metal out. I broke two drill bits and an easy out on one stud and was able to get it out. Of course the motor was on a stand. But if you hit the threads you will have to drill and heli-coil it. Good luck.
1996 GT (sold)
1997 Cobra
1993 Ranger GT (not broke)
Want an 03/04 Cobra
Born:5/23/97, Build # 5722 of 6961 Builds
Cobra GT is offline   Reply With Quote
Old 05-05-2009, 06:14 AM   #9
Region: Iowa
On the exhaust manifold/midpipe bolt... the shop had to cut it out with a plasma torch. That is obviously not a good idea for a head.
Good news and bad news blue-saleen Pre-2005 V6 Mustang 11 02-20-2010 10:24 AM
The bad news bobbyoooo 1996-2004 Mustang GT 10 11-26-2008 06:24 AM
bad news bobbyoooo Pre-2005 V6 Mustang 14 05-05-2008 02:38 PM
Bad News for GM 04MonteSS The Bar 38 03-23-2005 11:14 AM
Good news and Bad news Tbird232ci The Bar 8 11-15-2004 03:31 PM
01:29 PM
