Cam Install ? - Mustang Evolution
Old 07-29-2003, 02:51 PM   #1
dapack69's Avatar
Send a message via Yahoo to dapack69
Cam Install ?
I already have ported heads, Can I change the cam with the heads on? Or should I just take the heads off.
I have a bone stock steering wheel.
http://www.gotstang.com/profile.php?dapack69#jump
dapack69 is offline   Reply With Quote
Old 07-29-2003, 03:11 PM   #2
Send a message via AIM to el cheapo
you dont have to pull the heads. At least you didnt on my old 350. just pull the intakes and losen the rockers, unseat all the push tubes, and the cam should come out with no problems.
damn it school, why do you suck so bad??
el cheapo is offline   Reply With Quote
Old 07-29-2003, 03:23 PM   #3
dapack69's Avatar
What about upgrading the springs at the same time. I heard something about putting nylon string in the cylinder
Old 07-30-2003, 08:21 AM   #4
uhh, i dont know anything about that. I was under the impression that you had to pull the heads to change the springs. (Ive never done that)
Old 08-02-2003, 11:03 PM   #5
Ill be doing a cam swap in a few weeks.
The way Im swapping springs is using an air compressor adaptor that screws into the sprak plug holes. Put ~150psi into it constatly, and it should keep the valve up. There will also be enough force holding the valve up that the amount of force needed to compress the springs wont even be close ot moving the valve.
I talked to a mechanic friend about this and he said that is how you swap springs with th eheads on.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 08-02-2003, 11:04 PM   #6
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
YOu dont have to take the heads off when you change the cam. Its just a whole lot eaiser.
Rellik is offline   Reply With Quote
Old 09-04-2003, 01:40 AM   #7
Send a message via ICQ to TheSarge Send a message via AIM to TheSarge Send a message via Yahoo to TheSarge
WHoa~~~
If you don't pull the lifters, won't they block the lobes of the cam from lifter #1 when the stock cam comes out?
I know there is a good roller timing set out there somewhere, Morana maybe? Great time to swap out the timing chain when you're in the motor that far huh? Does someone make a better lifter too?
WHo's put in a new cam and got better power N/A? First things first ya know....;.
God Bless Our Troops!
In search of the best mods for the least price.
I'm always broke, I work for Uncle Sam!
SEMPER FI!!
TheSarge is offline   Reply With Quote
.. CAM? .. sledgehammer Pre-2005 V6 Mustang 5 12-16-2009 02:47 PM
Cam Install Guides PureVenom Pre-2005 V6 Mustang 3 06-04-2008 07:48 AM
3.8 V6 Comp Cam Performance Cam nmaraijko Mustang Parts for Sale and Wanted 0 11-15-2006 07:11 AM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
07:25 PM
