gauges (indiglo) - Mustang Evolution
Old 01-11-2005, 07:38 PM   #1
gauges (indiglo)
how can you hard wire gauges on a mustang. like have them turn on right when you pull the headlight knob (like stock) that way you dont have to run a separate switch just for the gauges.
Old 01-11-2005, 09:00 PM   #2
I liek gramer
WhiteStang99's Avatar
Yeah, you just splice the gauges into the parking wire (brown for me) in the overly complicated headlight wiring assembly.
Old 01-11-2005, 09:59 PM   #3
i had it set up with a switch because it has four wires. two for the switch. and one for +
and one for -
Old 01-11-2005, 11:47 PM   #4
I liek gramer
mine has a switch too.
Old 01-12-2005, 02:12 PM   #5
fast64's Avatar
i take the wire for the light in the gauge and splice it into the wire for a light in the dash or A/C panel (which ever is closest).
GO BRAVES
Old 01-12-2005, 08:40 PM   #6
i dont want to have a separate switch
Old 01-12-2005, 08:41 PM   #7
Ibanezplayer272's Avatar
Send a message via AIM to Ibanezplayer272 Send a message via MSN to Ibanezplayer272
Ditto
2007 Windveil Blue Mustang GT
Mods : Intake, Stubby antenna
Rolls are for fat chicks
Ibanezplayer272 is offline   Reply With Quote
Old 01-12-2005, 09:41 PM   #8
I liek gramer
no, i dont have an on/off switch, I have a switch for colors and a dial for intensity.
Old 01-12-2005, 10:23 PM   #9
see mine came with a on/off switch nothing more
Old 01-13-2005, 12:55 AM   #10
I liek gramer
ahhh
Old 01-13-2005, 04:34 PM   #11
i guessing it cant be done
Old 01-13-2005, 05:52 PM   #12
Send a message via MSN to RDS02Stang
You should still be able to wire it into your headlight switch. Just meter out which wire is hot when lights are on and cold when lights are off (I still think its the Brown wire in the center of the harness on the back of the light dimmer switch).
The other (black wire) should be connected to a solid ground.
Of course - check your instructions on the wiring
:patriot: Robert :patriot:ATI Procharger StageIII, Ported Plenum, 75mm TB, Bassani X-Pipe, FlowMaster Cat-Backs, Kenny Brown Full blown extreme matrix subframe setup, Bilstein shocks & struts, and lot's more.
RDS02Stang is offline   Reply With Quote
Old 01-21-2005, 11:26 PM   #13
yeah i have my main power supply from my head light switch. but i found out that the switch that comes with the gauges has to be put on because of some type of diode or capacitor in there
gauges gearbanger67 Classic Mustangs 4 01-02-2007 08:59 PM
gauges o3mustangGTafs Mustang Audio & Video 2 08-08-2006 04:15 PM
gauges o3mustangGTafs 1996-2004 Mustang GT 4 08-01-2006 09:08 AM
got gauges? whipster24 Pictures and Videos 19 04-10-2006 10:57 PM
Bumper Billet aluminum grill and reverse indiglo guages installed Rick0636 Mustang Audio & Video 10 04-18-2004 08:37 PM
12:41 AM
