At idle - Mustang Evolution
Old 07-29-2003, 03:24 PM   #1
Send a message via AIM to ASSEMbler
At idle
Car engine makes a ticking noise.
Checked the oil. Gets less when it's totally topped off, but is
still there.
Ideas?
ASSEMbler is offline   Reply With Quote
Old 07-29-2003, 03:35 PM   #2
Does it make this noise at idle? Does it get louder when you accelerate?
Old 07-29-2003, 03:47 PM   #3
dapack69's Avatar
Send a message via Yahoo to dapack69
Probrably your fuel injectors
dapack69 is offline   Reply With Quote
Old 07-29-2003, 04:19 PM   #4
It goes away when I get to speed. only at idle.
sounds like a belt or accessory on the belt making noise. It's not from the top of the engine.
SIG REMOVED FOR THE PRUDE
Old 07-29-2003, 04:19 PM   #5
More like the front.
Old 07-29-2003, 05:06 PM   #6
Danger Dude's Avatar
could be a lifter making the noise. when they partially collapse theat idle they will make noise when you accellerate they pump up and stop ticking. Take a rubber hose about 2 feet long hold one end to your ear and the other end move around the the valve cover and engine to isolate the sound and it will help you locate the tick
Old 07-29-2003, 11:39 PM   #7
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
our rockers are natrually loud. It just cuold be that.
They make a tapping type of a sound.
Rellik is offline   Reply With Quote
Old 08-01-2003, 11:06 AM   #8
The common problem associated with the ticking sound is a header leak.
Red6Banger is offline   Reply With Quote
Old 08-01-2003, 01:19 PM   #9
That is possible if he has recently changed his headers or put in new gaskets. But if he has the stock headers and has not done anything to them it is remote that the stock gaskets went bad. Fords exhaust gaskets are well made!!!
Old 08-01-2003, 01:30 PM   #10
What corey stated is true. Also, If it were an exhaust leak of some type, the sound would only get worse with acceleration. More exhaust at higher RPM's, would mean more noise from the engine compartment if it were an exhaust leak. Besides, most exhaust leaks are, IMO, the most recognizable sound an engine can make.
Old 08-01-2003, 02:26 PM   #11
What does your car idle at?
Old 08-03-2003, 08:21 AM   #12
Most ticking is the rockers. I *could* be a leak at the header, but if you exhaust is mostly stock, It prob wont be.
Use the tube idea and find out exactly where the tick is coming from.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 08-04-2003, 11:01 PM   #13
Send a message via AIM to greenflash00
IM willing to bet its the tensioner arm clicking. mine clicks at idle and you can hear it. Ever since i put on my ud pulley and changed belts, when the engine turns over it raises the arm a tiny bit up and down and makes a faint clicking noise
http://www.mustangmods.com/data/990/sig_2_resize.jpg
Gt takeoff exhaust with Flowtech Warlock mufflers, Mac CAI, ASP UDP, Flex Phenolic Spacers, 17 by 9 Cobra R's, 275/40s all around, FMS C-Springs, Tokico shocks and struts, FMS T-loc, FMS 4.10 gears, fordchip, 3000 stall PI tq converter, B&M Supercooler, and some various appearance stuff.
greenflash00 is offline   Reply With Quote
Old 08-04-2003, 11:57 PM   #14
Is your pulley on straight?
Old 08-07-2003, 01:54 AM   #15
It's the tensioner. Damn you think they just cobbled the v6 together and then went onto the v8. When will ford give some decent oem quality...
Idle Problem Help!! W225110 1979-1995 Mustang GT 7 03-30-2010 07:12 PM
Doesn't idle down. Joe_SHO Pre-2005 V6 Mustang 7 02-12-2009 07:44 AM
ruff idle noslow5ohh 1979-1995 Mustang GT 11 07-02-2008 09:01 PM
Unsteady Idle Ibanezplayer272 1979-1995 Mustang GT 21 06-04-2008 06:33 PM
how much vacume at idle initialb 1996-2004 Mustang GT 2 08-03-2006 10:54 AM
08:05 PM
