Fuel pump flow rate ? - Mustang Evolution
Old 01-12-2005, 07:27 PM   #1
As i stated in my previous post i'm getting a supercharger for my car. how much can the stock fule pump flow per hour. i'm putting 30 lb injectors in and people tell me i need a fuel pump but i was wondering if i could use the stock fuel pump ? i'm going with the procharger 7 psi intercooled kit if that helps
jedwards242000 is offline   Reply With Quote
Old 01-12-2005, 07:40 PM   #2
your stock fuel pump may be ok with only 5 psi but i would recommend getting a 255 lph in tank fuel pump. it is safer and if you don't get it and your set up isn't good enough then it could be quite expensive for not getting a $100 part, fuel pumps aren't expensive. you can even get a 300lph fuel pump for around $100 at www.velocitymustangperformance.com go for it, your won't regret it.
bigpomps is offline   Reply With Quote
Old 01-13-2005, 12:43 AM   #3
97Stallion's Avatar
This is what you should do. Go to my site, www.rdmotorsport.com, and click on the downloads button. Then you will see a program called dragmath. after you open it up, look towards the bottom and you'll see fuel requirement. You'll see stuff like fuel pressure requirements and fuel pump requirements. That should help you! But your stock fuel pump call support up to about 250-300bhp, so anything over that, you'll need a bigger one.
Living one day at a time!
Old 01-13-2005, 06:10 PM   #4
Send a message via MSN to RDS02Stang
I would recommend a 255lph pump - if you order the system from ATI, you can have them include it with the package.
Go to www.SuperChargers4Less.com and talk to the owner - let him know I sent you and he can normally hook you up with a good deal
:patriot: Robert :patriot:ATI Procharger StageIII, Ported Plenum, 75mm TB, Bassani X-Pipe, FlowMaster Cat-Backs, Kenny Brown Full blown extreme matrix subframe setup, Bilstein shocks & struts, and lot's more.
RDS02Stang is offline   Reply With Quote
Old 01-13-2005, 06:14 PM   #5
if you go 11psi i would upgrade but 6-7 the stock will be ok
Old 01-13-2005, 07:53 PM   #6
It might be worth upgrading the fuel pump incase you ever did decide to go to 11psi.
Mill is offline   Reply With Quote
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 03:22 PM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
fuel pump for v6 The Darkside Pre-2005 V6 Mustang 11 01-06-2009 09:27 PM
fuel pump?? Xx_1990GT_xX 1979-1995 Mustang GT 7 10-07-2008 06:37 AM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
09:19 PM
