Front Suspension - Mustang Evolution
Old 04-30-2009, 09:57 AM   #1
Front Suspension
My car has installed for the past six months the blue tokico shocks/struts, red lowering springs, rack & pinion bushings with offset and front sway bar end links by Energy Suspension. I didn't have the money for any other upgrades at the time. Recently I hit a curb with drivers wheel when the road was wet going downhill on a turn and it left my steering wheel in this position \, almost undriveable. I had it diagnosed by two alignment and brake shop. I chose the brand based on preference...probably chose Moog cuz they have the Nascar Performance logo on their box. This is what each shop recommended.
Shop 1
Front Control Arm Bushing Kit - Energy Suspension (both)
Lower Ball Joint - Moog (both)
Inner Tie Rod End - Moog (driver)
Shop 2
Same as above
Inner Tie Rod End - Moog (passenger)
Outer Tie Rod End - Moog (both)
Rack & Pinion Boots
I purchased all these items and to the recommended I added:
Caster Camber Plates - MM
Front Spring Isolators - Energy Suspension
Although I installeld the shock/struts, springs and bushings I don't feel comfortable installing these parts since they're mostly bushings or critical steering components. I'm afraid of overtightening since I don't have a torque wrench. I think and hope this will fix my sloppy suspension. Anyone have other recommendations I should upgrade at the same time?
villa029 is offline   Reply With Quote
Old 05-01-2009, 08:53 AM   #2
Re: Front Suspension
isolators that are urethane will raise the car up as they are thicker than the stock FYI
Old 05-01-2009, 11:31 AM   #3
I didn't think much about that, but I can live with that. When I installed the springs my original isolators were bitten into and way worn out just couldn't afford it to buy new ones at the time. I suspect it contributed to some of the squeeking in my suspension and my exhaust hangs really low so it may not be such a bad thing for me. My car is in the shop today and should be done by the end of today...real excited to try it out.
Old 05-01-2009, 02:33 PM   #4
it will raise the car up by about half an inch
Old 05-01-2009, 02:52 PM   #5
That's alright I don't want it slammed or anything like that. Looking for more of an OE look with performance. The drop on your red cobra is perfect.
Old 05-01-2009, 03:18 PM   #6
ty, its about 1.7 inches lower than stock I am just at the limit of drivability lol
Old 05-01-2009, 06:20 PM   #7
What do you mean...you wouldn't be able to drive it if it were lower? Does it bottom out or scrape?
Old 05-04-2009, 11:52 AM   #8
It turned out that it's not fixed the way I wanted. The steering is tight and feels good but still it has a wiggle. I think the steering may have something to do with the offset rack pinion bushings. The guy says the spindle on driver side is bent. How can I figure out what is truly wrong with my car and fix it once and for all?
Old 05-11-2009, 09:53 AM   #9
SaleenFiend's Avatar
Have your insurance become involved, as this ticket will probably need more repairs and you will possible continue to chase the issue. With your insurance company you will have someone that will FORCE a solution that you are satisfied.
Old 05-11-2009, 10:35 AM   #10
The Darkside's Avatar
Shop 1
Shop 2
Same as above
Rack & Pinion Boots
Hey how much did all this cost. my car is going to need a suspension upgrade. i have done everything now except that.
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 05-11-2009, 02:26 PM   #11
RyansQuick6's Avatar
You probably have a bent control arm, if not k-member as well. I don't see a cast spindle getting bent, it'll break first.
RyansQuick6 is offline   Reply With Quote
AJE Racing front suspension on 67 mustang CPRsm Classic Mustangs 16 08-10-2014 07:17 PM
New front suspension today mchaggis50 General Mustang Discussion 5 08-26-2009 01:04 PM
Front Suspension Question 00vertstang Pre-2005 V6 Mustang 2 09-29-2006 11:55 AM
09:30 AM
