Help help- fuel pump-help! - Mustang Evolution
Old 05-01-2009, 03:17 PM   #1
The Darkside's Avatar
Ok heres the deal so like months ago i bought this GT500 fuel pump dual system for my car with the harness ect ect. i TOLD the guy it was a V6, then me and him talked about my V6 for a while and NOW hes telling me that what i have is for a V8.
so do you guys know of any kits, or harness that would make this work with a V6. does anyone have another kit in mind for my V6?
thank you for your help guys, i have had no car now for over a week, its killen me!
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 05-01-2009, 07:39 PM   #2
Re: Help help- fuel pump-help!
dude for real, no one has any ideas??? venom? hot cobra? you guys got all the awnsers man
i bleed Race fuel!
Old 05-01-2009, 07:51 PM   #3
jimmy_beaner's Avatar
Region: Iowa
are you sure there is a difference in connectors? A link would help
Old 05-02-2009, 09:00 AM   #4
the fuel pump is the same for both the v6 and v8. boom! i got some answers too
iamdat is offline   Reply With Quote
Old 05-02-2009, 09:13 AM   #5
Region: Iowa
yes, but he's talking about the GT500 version. I'm pretty sure it would fit... I say give it a shot and see what happens
Old 05-02-2009, 09:28 AM   #6
what im getting to is that the v6>gt500 swap would be no different than the v8>gt500.
Old 05-02-2009, 09:31 AM   #7
Region: Iowa
yes, I agree.
Old 05-02-2009, 10:17 AM   #8
everything is the same you guys, except the end of the harness that gets ignition..... so we need a harness that is made for a v6. i think theres no such thing. do you guys think i should just rig it to get ignition.
i bleed Race fuel!
Old 05-02-2009, 10:49 AM   #9
Region: Iowa
ah, so it doesn't "plug in"? You may consider "rigging it", but be careful to insulate all the wires when you're done... having shorts so close to a tank of fuel would be a bad idea
Old 05-03-2009, 02:49 PM   #10
thats what the guys who sold us the pump said.....said we might be better just rigging it up. they said all you really need is to get electricity to it, everything else is fine.
i bleed Race fuel!
Old 05-04-2009, 08:04 AM   #11
SaleenFiend's Avatar
you need to sauter the connections and if you could run a bigger guage wire in the process to ensure the pumps are getting enough voltage and not overheating and melting the insulation. (Which could result in a fire)
What do you need GT Pumps for?? That's a lot of fuel pressure and supply you won't need unless you go with plenty of boost?
Old 05-04-2009, 08:11 AM   #12
you can probably buy the wiring harness end off of a gt500 from ford for rather cheap hopefully and then splice it in so it will plug into your pumps
Old 05-04-2009, 09:08 AM   #13
i needed it because my car is making very close to 400, like 390 at the crank, so my fuel pump isnt sufficant, every now and then if i let the battery run down ( have the ac on and the radio loud standing for over ten mins) then the car gives me a running lean code, as long as i was keeping the battery at maxium capacity i was ok. i got sick of that so i wanted to put in a stronger pump that works till 600 horses so i dont have to worry about it.
now its become a bigger issue, i can either leave the stock and let him tune my car down a bit, or find a way to make this work.
however guys i just got word that my guy wants to run a booster pump while keeping the same stock pump in it. not that i know how that works, but he said it will do the trick. so im going to return the gt500 pumps.......that in mind
anyone want to buy a gt500 fuel pump lol
i bleed Race fuel!
Old 05-04-2009, 09:32 AM   #14
a fuel pump is just an electric pump, increase voltage, increase output. plain and simple
thats what the boost-a-pump does, increase voltage to the fuel pump
Old 05-04-2009, 09:41 AM   #15
got yah! i guess thats what my guy is going to do!
i bleed Race fuel!
Old 05-04-2009, 02:19 PM   #16
what about the injectors do you have v8 injectors?
dalltx is offline   Reply With Quote
Old 05-04-2009, 02:27 PM   #17
huh? on these fords, all the injectors are the same. its either gonna have EV1 or EV6 connectors. older stuff uses EV1 and newer use EV6 but there are adapters to use with either.
Old 05-04-2009, 02:44 PM   #18
the stock GT has 21lb injectors right? not sure on the v6~ but I know if you boost the GT much over 5psi you need to upgrade to 29lb
Old 05-04-2009, 02:58 PM   #19
i have 39.5 lb fuel injectors in my car, they came with the procharger.
i bleed Race fuel!
Old 05-04-2009, 04:14 PM   #20
good god and thats a v6 im out of the loop damn what motor do you have in that thing obviously prochaged and how many horses you pushin?
Old 05-05-2009, 11:50 AM   #21
lol its a 4.0 vs the v8 which is a 4.6. at the crank im making about 390. thats why i needed the new pump, the stock pump cant handle that. Actually i dont know too many people whos v6 makes the same power as mine. I got a boy who make 365 at the crank but he doesnt have as many mods as me.
my car kills stock gts, but i have been crushed by a viper, gt500 and a z06 corvete. Still had to try! lol out of those the viper really smoked me.
i bleed Race fuel!
Old 05-05-2009, 11:58 AM   #22
yea there are some fast v6's out there, my guy i know has a 95 v6 with a single turbo, 700rwhhp
Old 05-05-2009, 03:48 PM   #23
HOLLY CRAP!! wow that is FAST!
i bleed Race fuel!
Old 05-06-2009, 04:14 PM   #24
Im sorry but whats fast? you mean powerful?? lol
Old 05-08-2009, 08:58 AM   #25
lol im sure its fast AND powerfull lol itll smoke my car without even trying lol
i bleed Race fuel!
Old 05-08-2009, 10:59 AM   #26
I was being a smart ***.. I know..
Old 05-08-2009, 02:45 PM   #27
Herbstang's Avatar
Won't expect anything less from you
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 04:22 PM
fuel pump for v6 The Darkside Pre-2005 V6 Mustang 11 01-06-2009 10:27 PM
fuel pump?? Xx_1990GT_xX 1979-1995 Mustang GT 7 10-07-2008 07:37 AM
Fuel pump lowflyn Mustang Parts for Sale and Wanted 4 08-01-2006 09:12 AM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-12-2005 12:04 AM
09:49 PM
