cranking - Mustang Evolution
Old 01-14-2005, 04:47 PM   #1
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
cranking
well i kno this is for a stang but im looking in to this project car, but it doesnt start, it seems to be in good condition but it just cranks. and its cranks instantly. but it just will not turn, does any one have any ideas what it could be, can i get like a little list of them? thanks.
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 01-14-2005, 05:42 PM   #2
it cranks or doesnt it? making the noise doesnt count? does it actually crank then wont idle and goes dead?
Old 01-14-2005, 06:37 PM   #3
I liek gramer
WhiteStang99's Avatar
i think he means it won't turn the engine over, but will make the noise where it's trying to.
Old 01-14-2005, 07:00 PM   #4
yea u can tell its trying but it just will not kick over, u kno that noise it makes like when its cold in one of our cars, like two or three sec before its starts? its makes that noise but will not start.
Delta Sigma Phi
www.DeltaArmsCo.com
Old 01-14-2005, 07:01 PM   #5
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
check the basics 1st..starter, alternator, battery..
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 01-14-2005, 09:19 PM   #6
MonteCitan's Avatar
it's cranking, but its not catching... starters good, batterys' good, it'd help to know what kinda car it is.. if its an 80's honda or other japanese import don't bother.. it could be any one of the 60+ vacuum lines causing problems
could be fuel delivery (very likely) do you hear the fuel pump prime when you hit the key on? (or is it carbeurated?)
spark delivery (almost as likely)
crank sensor (likely)
intake leak (very likely) such as a blown intake or head gasket, not allowing compression..
compression issue (timing jumped.. though it wouldn't sound right when its turning over if its this)
.. ... it could be any of a number of things
Old 01-15-2005, 09:12 AM   #7
o sorry it a 1993 probe gt with that 2.5 liter v6 24 valve. so its not a carb car.
Delta Sigma Phi
www.DeltaArmsCo.com
Car not cranking ballajb 1979-1995 Mustang GT 2 11-19-2009 09:32 AM
12:14 AM
