New Clutch (Problem) - Mustang Evolution
Old 01-15-2005, 02:37 AM   #1
PuReHeLL's Avatar
Send a message via AIM to PuReHeLL
Hey guys I just recently bout a month ago put in an aftermarket clutch called a saxs if anyone is familiar with clutch manufactures. Anyway its a cheap clutch but I'm wondering if my problem has to do with it. When first gear catches and while im lettin off clutch in first gear(first gear only) the car feels like its going to stall unless I gas the hell out of it. Sometimes worse than other times, could this mean my plates didnt settle right with my new clutch? If the car still runs fine should I worry about long term damage or risk gettin ripped off by tryin to get this problem fixed and ford dicking me around?
Any help would be great, thanks in advance
OuT --> PuReHeLL
http://www.mustangevolution.com/foru...ine=1107000257
PuReHeLL is offline   Reply With Quote
Old 01-15-2005, 04:54 PM   #2
97Stallion's Avatar
SOunds like you have a stock car and you don't have enough power to get the car moving without the aid of the gas pedal. And it would only do it in first gear because your car is at a complete stop. In any other gear you should be starting off at atleast 1500-2000 rpms, and the engine then produces enough torque to not stall. What year is your car and where do you live? You should update your profile.
Living one day at a time!
Old 01-15-2005, 05:00 PM   #3
hmmmmmm.^^^^^^ that would be my guess too. stiffer than stock?????
cjd10 is offline   Reply With Quote
Old 01-15-2005, 06:24 PM   #4
yea its grabbing to hard perhaps... but it could be an out of balance issue.
Old 01-15-2005, 06:53 PM   #5
PuReHeLL's Avatar
Lightbulb
Its a 98, Ive got flowmaster single exhuast system and custom intake. Also I drove it without any exhuast for about four months before I got the flowmaster set up. I think I know the problem. Thanks yall.
OuT --> PuReHeLL
Old 01-15-2005, 11:38 PM   #6
your clutch is chattering which is common in a lot of aftermarket clutches. I have a spec stage 3 puck clutch and it chatters like crazy. It may be balance wrong too though. the most common thing is clutch chatter.
bigpomps is offline   Reply With Quote
Old 01-16-2005, 12:35 PM   #7
You're right about that, my stage III SPEC chatters alot too. I'm sure that people around me, when I start out from a stop, think something is screwed up in the car the way it shudders a little.
Check The Ride Out... http://www.hpracing.net/mkonor.htm
Vortech SQ-2 w/2.62 pulley, Custom Stroked SSX 4.3l, G-Force T-5, SPEC 3 Clutch, Intercooler, CompuCar Nitrous Wet System, SVT Dual Fuel Pump/Tank, 42lb FMS Injectors, 90mm Lightning MAF, SCT Tuner Custom Setup by Velocity Mustang Perf, FMS 8.8 w/4.10 Gears, MAC Long Tube Headers
michael.konor is offline   Reply With Quote
Old 01-16-2005, 04:02 PM   #8
my car likes eating throw out bearings
Old 01-17-2005, 12:29 AM   #9
Really, how often do you go through a bearing?
clutch disc problem 1996v6stang Pre-2005 V6 Mustang 6 07-16-2010 10:33 AM
new clutch problem??? bluestang1724 Pre-2005 V6 Mustang 3 07-31-2007 04:46 PM
downshifting rumble...clutch problem?? maximus 1996-2004 Mustang GT 21 05-29-2007 05:27 PM
Clutch Problem! I think!! Scoot99V6Stang Pre-2005 V6 Mustang 5 03-21-2006 09:48 PM
Shifter clutch or tranny problem??? PA6shooter Pre-2005 V6 Mustang 10 04-28-2005 08:15 AM
03:43 PM
