Popping the clutch and rear ends - Mustang Evolution
Old 01-16-2005, 12:46 AM   #1
I was curious, what rpm range cant a v6 rear end take?
Exit_In_Red is offline   Reply With Quote
Old 01-16-2005, 10:56 AM   #2
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
if your stock any *should* be ok. but alot of it has to do with traction more then any thing else. if your on a drag strip with slicks and u have more the stock hp and you launch its not going to take much before the 7.5 gives up. if you on the street and you launch it with like good street tires you should be ok for a long time.
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 01-16-2005, 10:58 AM   #3
i have two 275s in the back. Should i be ok? Oh, and 245s in the front
Old 01-16-2005, 11:07 AM   #4
yea u should be fine but u can never kno when it comes to these thing. but if i were you and dropping the clutch alot and all i would deff invest the 800 and get a 8.8 to my door with 3.73s in it.
Delta Sigma Phi
www.DeltaArmsCo.com
Old 01-16-2005, 11:45 AM   #5
how much power do u really plan to have? even if you are dropping the clutch, the 7.5 wont break unless you have too much power or some slicks.
Old 01-16-2005, 03:45 PM   #6
its not the speed of the parts turning that will kill the rear end its the "shock" factor, if you take off at 6k and the rear tires just spin its not very hard on it cuz the parts are just turning, however if you take off from 6k with NO wheel spin at all and just GO the rear end will have a massive shock to it and will break lol, pretty much the stock 7.5 rear end on street tires will be fine, if you go to the track and drag it alot it will eventually break, but will last a while (if the install was good and the parts were new when you installed them)
with slicks... its not gonna last long
the spider gear will be what brakes.
Old 01-17-2005, 01:31 AM   #7
97Stallion's Avatar
Right, there is a misconception the the 7.5 is very weak. It's not! It's actually alot stronger than what people think. Brandon is correct about the dragging and everything. The 7.5 will take you to and from the track, but not on a daily basis with slicks on the car.
Living one day at a time!
Old 01-17-2005, 10:32 PM   #8
gotcha. thanks.
Old 01-17-2005, 10:34 PM   #9
Pretty much...if you drag the car on a regular basis, eventually you will kill the rear end. But it probably won't be an immediate thing.
Weird popping noise from rear iwannagofast 1996-2004 Mustang GT 1 05-12-2009 12:10 AM
Popping Noise 98StangGT 1996-2004 Mustang GT 8 08-04-2006 11:11 PM
9" rear ends FMFC Classic Mustangs 1 07-20-2006 08:18 AM
popping the doors!!!!! fast64 Pictures and Videos 9 10-28-2004 03:56 AM
Check out these prices for 8.8 rear ends in NYC/NJ. ASSEMbler Pre-2005 V6 Mustang 14 11-23-2003 07:39 PM
10:20 PM
