mustangworld home-made CAI? - Mustang Evolution
Old 01-16-2005, 04:18 PM   #1
Send a message via AIM to tedness
ok I was wondering if this really works. if its just as good as getting a MAC or Densecharger? Or if its best to just save and get one of those kits.
http://www.mustangworld.com/ourpics/fcar/coldair.htm
tedness is offline   Reply With Quote
Old 01-16-2005, 04:21 PM   #2
fast64's Avatar
looks kinda ghetto
GO BRAVES
Old 01-16-2005, 04:22 PM   #3
my car is all about the ghetto
Old 01-16-2005, 04:29 PM   #4
232stang01's Avatar
Send a message via AIM to 232stang01 Send a message via Yahoo to 232stang01
Just get an ebay CAI. best bang for your intake buck.
232stang01 is offline   Reply With Quote
Old 01-16-2005, 04:35 PM   #5
ya. maybe ill just wait and do that.
Old 01-16-2005, 04:36 PM   #6
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
that homemade cai is the poormans intake
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 01-16-2005, 04:38 PM   #7
dont cut corners and go all getto do it right or dont do it at all.
Old 01-16-2005, 04:39 PM   #8
232stang01's Avatar
werd
Old 01-18-2005, 12:10 PM   #9
Bane-'s Avatar
aslong as it gets the filter down away from the motor who cares? the tubing doesnt have that much effect on it,its just where the filter is...fenderwell is better then engine bay, etc
Old 01-18-2005, 12:20 PM   #10
232stang01's Avatar
A regular CAI will also get rid of the 'ribbed' portion of the intake tubing past the MAF. The factory air box still pulls air from the exact same location of the CAI. The point of the CAI is to smooth the passage of air into the motor. I'm not saying there's NO benifit to having the filter outside the engine compartment, but it's definately not the only reason to get one.
Like SpectorV said:
"do it right or don't do it at all."
Old 01-18-2005, 12:37 PM   #11
I agree. Works just as good I guarantee it.
I have an 01GT w/ frpp 3:73's, sportline springs, wms cold-air w/95mm mass-air, (ceramic) BBK equal length headers (ceramic) mac 70mm t. body, trickflow intake plenium, mac pro-chamber, flowmaster catback, Nitto drags, NX N20 150hp jets, & some good predator tuning! Best E.T. 11.79 @ 118.4mph :drive:
[IMG]C:\Documents and Settings\jon.straszewski\Desktop\TOP ****y to bar 020.JPG[/IMG]
Js281GT is offline   Reply With Quote
Old 01-18-2005, 12:56 PM   #12
Mjcorn23's Avatar
If you try to cut corners you will end up hating yourself for it in the long run. It is like the old saying that you get what you pay for. That doesn't mean to go out and buy the most expensive things that you can find but shop smart and don't impulse buy. Do research and check into things it will save you a headache later.
2002 Laser Red V6 mustang
"Six Shooter"
15.7@93mph lots of wheel spin
Mustang anything else is just a wanna be
http://i16.photobucket.com/albums/b9...n123/corn2.gif
Mjcorn23 is offline   Reply With Quote
Old 01-18-2005, 01:02 PM   #13
Bane-'s Avatar
I agree to a certain point, but this would be one of those instances were its not cutting corners and would be smarter...you dont need a chrome peice of aluminum to have cold air intake, yea looks a lil better then black plastic hose but they both serve the same purpose and both get the job down just as equal...and id put money on it...if u have a cai but the filter is still next to the motor your still sucking in hotair even with your expensive chrome plated aluminum tube. if its not in the fender well or lower like in the airdam like the march ramair system..its not really helping you any. all in all....so what if you have a "real" cai if its next to the motor its still useless.
Old 01-18-2005, 01:05 PM   #14
232stang01's Avatar
I agree. When you can get a CAI off of e-bay shipped to your door for 65 bucks or less, that you can put on by yourself, that requires no fabrication, and that many other people use with no problems, why screw around with trying to make one? Hardly seems worth all the extra effort to me. I mean, what if you didn't do it right and your filter falls off/out on a road trip?
There are many other things you can do that don't cost much, like the gas pedal mod. That one is worth the time.
But you should do what you want to do, after all, it's your ride.
Good luck!
Old 01-18-2005, 01:37 PM   #15
Mjcorn23's Avatar
I disagree the black hose is the most constricting part of the intake and when you buy the CAI that is the main part you want to replace to get better air flow
"Six Shooter"
Old 01-18-2005, 01:39 PM   #16
Bane-'s Avatar
3" is 3" (3" being example) doesnt matter if its aluminum or plastic if its smooth on the inside it dont matter and they will flow the same, Ive never seen or heard of aluminum being able to flow better then plastic thru the same diameter, then we would have aluminum tubes for all of our plumbing and not PVC since its basically plastic. the most important part of any cai is where the filter is sucking air in.
Old 01-18-2005, 02:00 PM   #17
232stang01's Avatar
Turbulence. the air flowing through the ribbed black plastic tube is more turbulent than the smooth inner surface of the aluminum tubing.
I've done the K&N filter only, removed the silencer, the march ram air, and the CAI. The CAI gives the best results.
Old 01-18-2005, 02:02 PM   #18
Mjcorn23's Avatar
That is what I was trying to say it just didn't come out right I guess
"Six Shooter"
Old 01-18-2005, 02:08 PM   #19
232stang01's Avatar
Too bad someone doesn't just take a velometer and measure the drop in velocity across the black platic tube vs. the aluminum one. That'd clear it right up. Bummer I don't have access to one any more.
Old 01-18-2005, 02:13 PM   #20
Mjcorn23's Avatar
I will see if I can get my hands on one and I will do it
"Six Shooter"
Old 01-18-2005, 02:20 PM   #21
Bane-'s Avatar
I said if both peices are smooth...never anything about the ribbed plastic one lol....i put a smooth one on my 88 cant notice anything cuz i cant drive it yet..no tags or anything but im going to be going to massair whenever i get more money and the exhaust is done, next week or so ill have longtubes and a offroad H..longtubes will be here thursday
Old 01-18-2005, 02:30 PM   #22
232stang01's Avatar
I'm confused as to what it is you're talking about then. If you were to do the MW PVC thing, you'd be doing little to nothing for flow. Did you notice that the air silencer snorkel looking thing goes out to the exact same spot that the PVC thing would? All that would be doing is moving the filter. You'd still have a 90 degree bend, and you'd still have the 'ribbed' plastic tubing after the MAF. Doing the MW thing is pretty much a waste of time. The CAI however (and most are the fenderwell type for v6's, not the underhood type) adds a smooth aluminum tube from the MAF to the throttle body, hence getting rid of the lesser flowing black 'ribbed' tube.
Are we not talking about the same thing?
Old 01-18-2005, 02:33 PM   #23
Mjcorn23's Avatar
That is the same thing that I thought 2:
"Six Shooter"
Old 01-18-2005, 02:53 PM   #24
Bane-'s Avatar
i was just talking in general...if both peices are smooth it doesnt matter lol being aluminum or smooth plastic. i dont have to worry about that anyway yet with the 88...havnt converted to mass air yet..so i have no maf to worry bout
Old 01-18-2005, 07:47 PM   #25
232stang01's Avatar
the point being that the piece after the MAF isn't smooth. A CAI will thake care of that. I'm sore you could fab something to replace the whole intake tract, but after all that, you'd have spent more time, energy, and quite possibly money to engineer something that's already been done.
Old 01-18-2005, 09:45 PM   #26
Bane-'s Avatar
well it made sense in my head, i just cant type it evedently...
/me sits in the corner by himself
Old 01-19-2005, 12:07 AM   #27
232stang01's Avatar
Don't get me wrong, I'm not baggin' on you. I just want to be sure we're on the same page and giving tedness(?) the right info.
cai
Home made dyno PureVenom Pictures and Videos 2 03-05-2007 03:03 PM
I made it home! Ghostrider304 The Bar 3 06-20-2005 08:47 PM
An interesting look into the lives of the mustangworld SpectorV The Bar 10 12-12-2004 11:49 AM
Look what I made (cut-to-fit CAI) RGR Pre-2005 V6 Mustang 29 11-16-2003 09:51 PM
so who here made 232 your home? Rellik The Bar 46 08-10-2003 01:04 AM
01:43 PM
