deleting accesories on a supercharged engine??? - Mustang Evolution
Old 01-17-2005, 05:12 PM   #1
fast64's Avatar
I am going to be buyinig a buddies used supercharger that was on his 93 5.0 coupe that has A/C, power steering, etc. I will NOT have power steering, A/C, or smog pump on my 5.0. Can I just delete these things and get a shorter belt or will I have to get idlers??
GO BRAVES
Old 01-17-2005, 05:46 PM   #2
fast64's Avatar
also, i will be running an 8lb boost pulley, what size fuel injectors will i need? 24#? and will i need a larger than stock fuel pump?
GO BRAVES
Old 01-17-2005, 06:11 PM   #3
01mineralgrey6's Avatar
I would think that as long as there will be clearance enough to were the belt wont touch itself than a shorter belt may be all you need...other wise id say get idlers
-Tony
'99 cobra 'vert
Old 01-18-2005, 04:44 PM   #4
fast64's Avatar
ttt i want some more opinions.....
GO BRAVES
Old 01-18-2005, 04:46 PM   #5
Mjcorn23's Avatar
The shorter belt should work brotha also I am not so sure that you will need 24# injectors I would go with 19#
2002 Laser Red V6 mustang
"Six Shooter"
15.7@93mph lots of wheel spin
Mustang anything else is just a wanna be
http://i16.photobucket.com/albums/b9...n123/corn2.gif
Mjcorn23 is offline   Reply With Quote
Old 01-18-2005, 05:05 PM   #6
fast64's Avatar
19#s are stockers (what i got now)
GO BRAVES
Old 01-18-2005, 05:12 PM   #7
Mjcorn23's Avatar
I know but I don't think that you would need 24# not yet but I could be wrong
"Six Shooter"
Old 01-20-2005, 11:11 PM   #8
Send a message via AIM to tedness
my guess is if you found the right belt that won't like rubbing itself it should be fine. but idlers are a safer bet if you don't wanna deal with the possibility of having to put them in with yet another belt after trying without them.
tedness is offline   Reply With Quote
Old 01-21-2005, 05:19 AM   #9
fast64's Avatar
i think i'll just try a shorter built first and hopefully save myself a couple hundred dollars (that i can spend on the interior and suspension )
GO BRAVES
Old 02-18-2005, 06:46 PM   #10
RGR
Send a message via AIM to RGR
Depends on the routing, if certain accessories are deleted
then idlers need to be put in for routing. If you have a
good spot (like in place of something you deleted) you
can get by w/o a new idler. Get my drift???
I think the mounting bracket might have 1 on there, so that helps
with the idler issue. You just need good belt wrap on the SC pulley,
but at 8# I doubt you get any slip at all.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 02-18-2005, 06:55 PM   #11
fast64's Avatar
i discovered that i need one idler pulley so that the belt hits the water pump correctly
GO BRAVES
Old 02-18-2005, 07:58 PM   #12
RGR
That figures, most setups w/o many accessories need at least 1 idler...
Old 02-18-2005, 09:16 PM   #13
fast64's Avatar
i also had to flip my alternator to make room for the supercharger, that wasnt a big deal though
GO BRAVES
Old 02-21-2005, 03:48 PM   #14
bluemustang's Avatar
just buy the simple delete kits they have. and buy the shorter belt.
as for injectors you should be fine wit your stock 19s
im running my stock 19 and only running 7 psi at the moment but once i get the new tune this spring its a whole differ story
NX intercooler spray kit+accesories!! 99MustangGTman Mustang Parts for Sale and Wanted 9 07-16-2008 07:42 PM
Vortech supercharged V6 engine for sale 232SCstang Mustang Parts for Sale and Wanted 25 05-24-2004 05:02 PM
03:43 AM
