mach 1 gauge cluster - Mustang Evolution
Old 01-18-2005, 08:09 AM   #1
Send a message via AIM to whitev6stang03 Send a message via MSN to whitev6stang03 Send a message via Yahoo to whitev6stang03
I was woundering, what would happen if I put on a mach 1 gauge cluster on a 2003 v6 stang? Would my needle mark correct? or mark as if i had my v6 gauges?
whitev6stang03 is offline   Reply With Quote
Old 01-18-2005, 10:09 AM   #2
I liek gramer
WhiteStang99's Avatar
the Mach 1 i think has GT gauges. You're speedo would be off and definitely need recalibrated for it to work properly on your six.
Old 01-18-2005, 10:20 AM   #3
Bane-'s Avatar
i think the mach's gauges are a lil diff then GT ones, but thats besides the point..like whitestang said above, it will need to be recalibrated to work with those increments in mph
Old 01-18-2005, 10:31 AM   #4
I liek gramer
well, whether or not they are the same as GT gauges, they will not work properly on your six unless recalibrated. Speed Cal is something you could look into. I don't have one, but some ppl on here do.
Old 01-18-2005, 12:06 PM   #5
Mjcorn23's Avatar
I personally wouldn't do it. If you are wanting to get some different gages look into something like Speedhut.com they have tons of things that should be to your liking
2002 Laser Red V6 mustang
"Six Shooter"
15.7@93mph lots of wheel spin
Mustang anything else is just a wanna be
http://i16.photobucket.com/albums/b9...n123/corn2.gif
Mjcorn23 is offline   Reply With Quote
Old 01-19-2005, 03:49 PM   #6
97Stallion's Avatar
I'm not sure you really would need to get your car calibrated. If you took the entire cluster from a GT it just might work. The calibration is usually in the cluster itself. Like on my car I have a 150mph speedometer, and for to make it work correctly, I needed to change out the drive gear in the transmission and change the cluster that's all. The 99+ models don't have a drive gear so you might just get lucky. it's worth a shot I'd say!
Living one day at a time!
Old 01-20-2005, 11:34 AM   #7
I would want to try it but, finding a mach 1 gauge cluster being sold is a rare find.
Old 01-20-2005, 11:36 AM   #8
I liek gramer
I assumed you had access to one, since they aren't exactly easy finds, lol.
Old 01-20-2005, 11:13 PM   #9
Send a message via AIM to tedness
someone wrapped their mach1 around a light pole a while back. maybe they still have it to sell the cluster
tedness is offline   Reply With Quote
Old 01-21-2005, 08:15 AM   #10
Well maybe you could help me out........ try them out on your car and tell me if it works...
Old 01-21-2005, 03:48 PM   #11
Send a message via AIM to NJStang86
http://cgi.ebay.com/ebaymotors/ws/eB...949273105&rd=1
There ya go...
I would go the route you are, but it's too much more expensive to do it that way. I'm just gonna get the stainless guage bezel from UPR.
Good luck with the guages, tho...Lemme know how it goes
-Frank-
http://home.earthlink.net/~riz3742/sig2.jpg
2003 Ford Mustang Dark Shadow Gray Coupe - 15.616 @ 87.24 (work in progress)
NJStang86 is offline   Reply With Quote
Old 01-22-2005, 10:05 PM   #12
There ya go...
i don't think its so much the bezel as it is the old-school style numbers on the gauge that he likes. thats what i like
Old 01-22-2005, 10:42 PM   #13
timpryor's Avatar
not to mention the redline on the mach is ALOT higher than the GT's or V-6's. I think you would have to have your ECU reflashed in order to make them work right
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 01-22-2005, 10:51 PM   #14
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
might be better off going to speedhut and seeing if they can custom make a set for you that ressembles the mach-1 guages so you dont have to go through the trouble of calabration and flashing the ecu
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Aftermarket Gauge Cluster for mustangs KustomSaturn 1979-1995 Mustang GT 8 02-26-2009 06:46 PM
New Gauge Cluster Background IMAPYRO Pre-2005 V6 Mustang 3 04-14-2008 05:44 PM
99-04 autometer lunar gauge cluster notstock02gt Mustang Parts for Sale and Wanted 4 05-09-2007 11:00 AM
2001 gauge cluster whitev6stang03 Pre-2005 V6 Mustang 5 12-10-2005 12:26 PM
99-04 GT Gauge Cluster > '02 V6?? mattstang Mustang Audio & Video 8 12-15-2003 08:13 AM
12:46 AM
