Suspension and steering - Mustang Evolution
Old 01-20-2005, 10:14 AM   #1
Matt'sredbeauty's Avatar
Ok ever since ive put 18"s on my v6 (which had I believe 15"s) its doesn't handle very good at all, like it sucks big time, is there anything extra I shouldve installed or done when getting them? I know nothing when it comes to suspension. if I requries alot, I wouldn't mind lowering it about 1", but i don't know how or what I need to do, Thanks for the help ahead of time. Matt
Matt'sredbeauty is offline   Reply With Quote
Old 01-20-2005, 10:28 AM   #2
I've never really heard about this happening...but I dunno man. Suspension never hurts. And a small drop wouldn't hurt either.
Old 01-20-2005, 10:32 AM   #3
its a 97 so some of the stuff maybe wearing out, ie. shocks struts springs, i don't know im just naming stuff, but I would like a little drop, its like i can feel every little bump in the road and stuff like that
Old 01-20-2005, 11:04 AM   #4
Danger Dude's Avatar
sounds more like a tire issue than a rim issue. The larger the diameter rim the lower the side wall and more rough ride if you keep the same tire height. Ultra low profile tires might handle great but they suck *** for comfort of ride!!!
Old 01-20-2005, 11:07 AM   #5
Zim
You want to **** me?
Zim's Avatar
agreed... its just the price you pay to have your car look nice. Gotta remember, a mustang was never meant to ride like a lincoln. The v6 theoretically should ride the best in stock form as far as comfort goes, but as soon as you do things that put it closer to the performance models, the more its gonna drive like the performance models.
I like toys
Old 01-20-2005, 11:12 AM   #6
All Hi-performance cars ride rough unless on smooth roads. The only exception is Car with active suspension that have computer controlled suspension and that is found only in very high dollar exotic cars
Old 01-20-2005, 11:53 AM   #7
My car rides extremely rough even with the new shocks and struts but its look so good with the 1.8" drop in front a 1.25" drop in the back
Old 01-20-2005, 12:26 PM   #8
Tbird232ci's Avatar
and 87-88 Turbo Coupes
basically, if you want the car to handle good, you have to suffer with a rough ride, if you want it to ride good, you have to suffer with crappy handling...theres no real way around it
Old 01-20-2005, 12:31 PM   #9
Finding the happy medium is the key
Old 01-20-2005, 12:38 PM   #10
yes the smaller the tire sidewall the more you feel the bumps. since you have to run a lower tire on 18's there is no way out.
Old 01-20-2005, 12:53 PM   #11
how much should i lower?, do I only need the springs?
Old 01-20-2005, 01:08 PM   #12
lowering will cause it to be even rougher
Old 01-20-2005, 10:53 PM   #13
fastmustangs1's Avatar
Thumbs up
What do you have as far as suspension goes. Yes the factory suspension does however suck for our cars, but there is always room for improvement.
Try Maximum Motorsports they make different kits for a variety of levels. From just springs and shocks to the advanced Panhard Bar, Torque Arm setup. It will also depend on what your plans are for the car.
Matt
fastmustangs1 is offline   Reply With Quote
Old 01-21-2005, 04:52 AM   #14
The problem with any upgrades in suspension will ultimately make the car ride harsher than it already is. my advice is if you dont want the ride to get worse get some Ford Racing "B" springs. They will lower your car approx 1.2" The ride is close to a Bullitt ride.
http://www.gefracing.com/Merchant2/m...ry_Code=46SUSP
Old 01-21-2005, 05:55 AM   #15
do i have to get the bumpster thing, and cc, and the bushings?
Old 01-21-2005, 06:15 AM   #16
No with a 1.2 drop none of that is required
Old 01-22-2005, 05:23 PM   #17
with a fox chassis you pay for performance with harshness.... you want bigger rims that will handle better you pay for it with a bad ride.... its not that bad but noticable, the tire choice is key of course.
Old 01-22-2005, 05:24 PM   #18
with a 1.2 drop cc plates are not really needed, but with a wide tire if you start to see wearing on the inside edge you may need a set to solve it (stock specs arnt the best for tire wear and long life) you do have to pay the price of inside edge tire wear a bit if you want em set up for better handleing alignment wise.
Old 02-19-2005, 08:51 PM   #19
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
C springs are cheap and good. That's what I'm running. It is a fair amount rougher ride than stock but it handles WAY better.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 02-19-2005, 10:56 PM   #20
agreed
V6 Steering HEC Pre-2005 V6 Mustang 7 03-01-2010 01:51 PM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
Suspension & Steering Problems. megax29 Pre-2005 V6 Mustang 5 01-05-2009 05:48 PM
What steering wheel is this? HotRod.riguez Mustang Audio & Video 5 11-28-2006 09:19 AM
Steering Wheel natebest2000 Mustang Audio & Video 7 02-16-2005 12:22 PM
11:25 AM
