Mad about my car...any suggestions - Mustang Evolution
Old 01-25-2005, 12:24 PM   #1
Send a message via AIM to canman
About a month ago in the morning I went to start my car on a cold morning and nothing happened so I had to go to school. I came home and jiggled the battery connections, and then cleaned them and reconnected. The car worked fine for another month. We got something like 10-15" of snow, and the car was buried for 2 days. I dug it out, and it worked fine that day. This morning before school, I went to start it again, but it didn't work. I barely had any gas, so I figured it was just frozen and went to school. I came home and started the car just for kicks and it started on the first try. I then drove it to the gas station, turned it off to get gas. When I went to start it again, it once again didn't work, so it's stuck at the gas station right now. The connections to the battery are fine, we tried jumping it twice, all other electical appliances work fine. I'm pretty sure it's the starter but I was just wodnering if anyone had any other ideas on what to do other than completely replacing the starter.
canman is offline   Reply With Quote
Old 01-25-2005, 12:38 PM   #2
could also be the alterntor
Old 01-25-2005, 12:42 PM   #3
I don't think it's the alternator Brandon, he says it won't start sometimes but will start other times.
Have you tried just checking the connections between your battery and starter real well? That could be part of it. It might be something as simple as a loose wire somewhere, there could be a short somewhere, etc.
That's about what I can think of...
Old 01-25-2005, 02:55 PM   #4
Yeah I was thinking it could possibly be the connection between the battery and the starter...I got it towed like an hour ago to a mechanic and he's checkin it out now....hopefully I don't need a new starter cause they aren't cheap
Old 01-25-2005, 03:01 PM   #5
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
i have friend whos having similar problem...btw where in jersey ?
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 01-25-2005, 03:10 PM   #6
Ponycarman's Avatar
Batteries can fail like that. My MIL's Beetle like to do this. It'll run the accessories just fione, but put a heavy load like a starter on it and nothing happens.
An internal break in the battery is usually the culprit. I'd have the battery tested.
Cold weather really tend to aggravate battery issues too.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 01-25-2005, 03:35 PM   #7
Central Jersey, right by Princeton...Hillsborough's the town name.
I'm hoping that it's just a battery problem...I should know tomorrow once the mechanic looks at it.
Old 01-25-2005, 03:37 PM   #8
Dark02Pony's Avatar
oh alright im up north morris co..parsippany
Old 01-25-2005, 05:51 PM   #9
MonteCitan's Avatar
I'm down south, near millville
my 89's had this problem before... my positive battery cable (the short one from the battery to the starter solenoid) got so corroded inside it basically acted like an open circuit.. I had no power to anything though
if jumping it didn't work the battery's either fully dead or fine, and you have a starter issue.. or your clutch pedal switch is inop (If you have a manual) or your pats system is acting up (the cars typically crank but don't start, but I've seen some not even crank with a pats failed key..) could be your ignition switch is going down the tubes.. could be any number of things
let me know what the mechanic finds out, I'm curious
Old 01-26-2005, 03:29 PM   #10
Alright we got the battery replaced but it turns out it was probably an issue with the security system. Whenever I turned the car off, in order to be able to start the car again I had to press the unlock button on my keypad. Even if I did not lock the car and was in it the whole time doing something like getting gas, I would still have to push the unlock key to get the car to start. I pushed that little orange blinking button by the headlight knob and I think I fixed that problem. I just feel like an idiot because I got the car towed and the battery replaced and that probably wasn't even the problem.
Old 01-26-2005, 03:49 PM   #11
if you cant find it at least have the alt checked but as sait it may short and then work fine..... one of those check an item and go to the next till its found.
Old 01-26-2005, 04:11 PM   #12
MonteCitan's Avatar
little orange button?
so you have an aftermarket alarm/remote start installed with a kill switch? ..
Old 01-27-2005, 02:37 PM   #13
Well the orange button i believe is stock...its the one that blinks when the car turns off? I'm not sure. Just called the previous owner and he forgot to tell me that an aftermarket security system was also installed that won't let the car start unless you push the unlock button first....blew $150 on towing and a new battery because of it
overweight woman mad cause she's too big for car hottcobra The Bar 22 02-05-2009 08:15 AM
Suggestions on a new car canman The Bar 27 06-23-2005 08:23 PM
Okay now i'm mad sonic04edge The Bar 26 04-05-2005 04:17 PM
Mad And Bored coolstang Pre-2005 V6 Mustang 13 02-22-2005 02:35 PM
Mad...... Brent Mustang Audio & Video 9 08-17-2003 05:52 AM
07:04 PM
