Throttle Body Questions - Mustang Evolution
Old 01-27-2005, 12:15 PM   #1
Ok, I am looking for an aftermarket throttle body for an 03 V6. The car also has a MAC straight shot air intake on it.
What is the stock size?
How large can I go and still attach to the stock manifold?
What would be the reccommended size for best performance?
What is the advantage of the spacer that can be purchased?
Thanks for your help and any other info you can spare!
JBLaw22 is offline   Reply With Quote
Old 01-27-2005, 12:33 PM   #2
slvr2000stang's Avatar
Stock is 60mm.
Unless you are adding a power adder of major engine work, it's not worth it & you may loose hp going to a larger TB.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 01-27-2005, 12:36 PM   #3
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
throttle bodys for example 70mm work better when you have done an upper and lower intake manifold
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 01-27-2005, 02:25 PM   #4
RGR
Send a message via AIM to RGR
1. What is the stock size?
2. How large can I go and still attach to the stock manifold?
3. What would be the recommended size for best performance?
4. What is the advantage of the spacer that can be purchased?
1. 60mm, and available sizes are also 65mm and 70mm.
You can get any of these bore up to 2 or 3mm oversized
and the true aftermarket ones maybe up to +5mm.
2. I have done the 70mm without welding the flange, but above that
is probably goning to need welded, and most shops have to weld to
get the 70 to fit, but I use a special trick
3. For most 3.8's, I recommend 60-65mm but anything over the
stock 60 really needs lots of porting to the crossover tube if not
post removal. You might be able to use a bored 60 (62-63) if the
crossover is properly ported but has the posts intact. But that is
the Max, according to the cross sectional airflow calculations and
the "cheat factor".
4. None. If it helps on any engine, and I doubt it does, this one has a
specially designed crossover that in my opinion would actually benefit
from less swirl instead of more due to the shape and design of it.
But that is just my opinion, and I can actually mod a TB to "swirl" the
air probably as effectively as those spacers if not more so. Most of them
actually have a design that looks restrictive rather than swirl producing
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Should i get a throttle body? blackonblack Pre-2005 V6 Mustang 21 12-07-2009 07:21 AM
throttle body ? wvstang5.0ho 1979-1995 Mustang GT 16 07-29-2008 10:48 AM
throttle body kingboy23 2005-2010 Mustang GT 7 05-06-2008 06:31 AM
throttle body sonicpony Pre-2005 V6 Mustang 2 09-09-2007 12:23 AM
70 or 75 mm throttle body????? greg_g70 1996-2004 Mustang GT 9 12-20-2004 09:58 AM
06:02 PM
