adjusting the clutch? - Mustang Evolution
Old 01-27-2005, 04:03 PM   #1
Send a message via AIM to Murph00
Lets start off by saying that I do not know much about manual cars, (I'm learning), I was looking up on v6stangs and saw that you should adjust your clutch every 5k miles? what is the adjusting do? Ive got a 3.8l with 50,000 mi and I doubt this has ever been done,and is this something I can do. When should I take my baby in to get the tranny and clutch looked at by a professional?
Murph00 is offline   Reply With Quote
Old 01-27-2005, 04:41 PM   #2
i belive that the 3.8 has a self adjusting quadrant
Old 01-27-2005, 04:42 PM   #3
unlees you do what the manual suggest, put the car into first then pull the pedal all the way up then push down you should hear a click and it is adjusted
Old 01-27-2005, 04:45 PM   #4
thanks
Old 01-27-2005, 05:02 PM   #5
the stock turd of a quadrent can be adjustest by rasing up on the petal and pushing it in slow, but it blows and dont last.... the best thing to do is buy a UPR quadrent and firewall adjuster along with a MM petal height adjuster (else the petal will come ALL THE WAY UP and stay that way, it just wont start to pull the clutch cable (engage) until down lower....)
with the height adjuster you can lower the petal and bring the adjustment correctly to it, you want ONLY a half inch of slack (from where the clutch is not slipping from where it starts to slip. from where the petal is when its all the way out and CANT go any farther even with you pulling up on it.
Adjusting the Clutch pringle9666 Pre-2005 V6 Mustang 10 06-14-2010 11:18 AM
Adjusting Idle and Timing sonicpony03 Pre-2005 V6 Mustang 1 07-23-2008 08:14 PM
adjusting the carb on an 82 GL? I_luv_HP&trq Pre-2005 V6 Mustang 8 09-28-2005 12:14 PM
best clutch ? jedwards242000 Pre-2005 V6 Mustang 5 04-09-2005 03:21 PM
?adjusting the cam position sensor? Horse Pre-2005 V6 Mustang 24 10-18-2004 06:01 PM
10:48 AM
