V6 Quarter Mile Question - Mustang Evolution
Old 01-27-2005, 06:39 PM   #1
DOING RESEARCH- cant find accurate readings, can anyone tell me a stock 3.6 mustang convertible 5 speed runs in the 1/4 mile???????
DMAC is offline   Reply With Quote
Old 01-27-2005, 06:48 PM   #2
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
3.8 acually what year ?
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 01-27-2005, 06:51 PM   #3
slvr2000stang's Avatar
Any answers you get will also depend on driver ability & weather conditions.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 01-27-2005, 06:53 PM   #4
Dark02Pony's Avatar
thats very true,, 60' time plays a big part in your 1/4 mile time as well
Old 01-27-2005, 07:43 PM   #5
97Stallion's Avatar
well supposably 94-98 is about 17 secs flat and 99+ is about 16.5
Living one day at a time!
Old 01-27-2005, 08:50 PM   #6
Sounds about right Rob.
2000 Vert 4R70W
Old 01-27-2005, 09:05 PM   #7
Danger Dude's Avatar
Rob, Kirk Arn't you glad we are lower than that now
I remember before I modded I was thoroughly disgruntled with the lack of speed, But I knew I could rebuild her. I would make her stronger, faster, improve handling, Improve her looks and feel then after I was thru with my Wife I went to work on my car DOOH!!! k:
Old 01-27-2005, 10:07 PM   #8
I liek gramer
WhiteStang99's Avatar
bahahahahahahahhaha! ^
Old 01-27-2005, 11:12 PM   #9
97Stallion's Avatar
Old 01-28-2005, 12:33 AM   #10
red herring's Avatar
Send a message via AIM to red herring
i expected more out of them than that...i'm disappointed. Especially from a 3.8-3.9 litre. Mine is only 2.5 inline 6, wrx has a 2.5 flat 4 (although turbo charged) 350z only has a 3.5 litre and puts out some good numbers
red herring is offline   Reply With Quote
Old 01-28-2005, 12:36 AM   #11
v6 mustang wasnt built for speed unlike those cars you mentioned
Old 01-28-2005, 12:36 AM   #12
Dark02Pony's Avatar
Old 01-28-2005, 04:02 PM   #13
since when is 217hp and around that in tq WITH A TURBO decent lol give me 10 psi and ill put down quite a bit more than that
Old 01-28-2005, 05:37 PM   #14
Any car that was built without a turbo does extraordinarily well with one in comparison to a car that has a turbo stock because they're built differently and have to stay within more guidelines or criteria. Even mkiv supras do a hell of a lot better when changing to a better turbo or converting to single. Turbos that come stock in cars aren't comparable to aftermarket ones. Can't you figure out displacement with a turbo and it's psi? Find out what displacement a wrx would have with it's psi and see if you would still put down more than that. Especially once you get into sti territory which runs 13's and has a 2.0 or 2.5 litre.
Old 01-28-2005, 06:13 PM   #15
it is true that the emmision laws crack down on turboed cars. ill still take my 03 snake though
Old 01-28-2005, 06:14 PM   #16
You have a cobra? I didn't know that *goes back to spectorv coolness thread* You're cooler than I thought
Old 01-28-2005, 06:27 PM   #17
no sorry i ment that as I would take and 03 cobra lol i wish so once again im not cool.
Old 02-01-2005, 01:13 AM   #18
PuReHeLL's Avatar
Send a message via AIM to PuReHeLL
With my stock v6 5 speed my best run was 16.4@88mph. Otherwise high 16's to low 17's sounds about right. I think the 1/4 is all about the launch and shifting ability.
OuT --> PuReHeLL
http://www.mustangevolution.com/foru...ine=1107000257
PuReHeLL is offline   Reply With Quote
Old 02-22-2005, 01:29 PM   #19
i got a 1999 v6 if that changes anything i owuld figure the 1998 and under are slower considering the disgusting lack of HP.
Old 02-22-2005, 02:15 PM   #20
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Look at my garage... download the 4 videos I ran against Chris... that will show you what a 99 will do to a 2001
Rellik is offline   Reply With Quote
Old 02-22-2005, 02:42 PM   #21
a few people have stated that it is 16.5 but i find that hard to believe for the 5-speed , not automatic, the auto i believe but i figured the 5-speed convertibles were faster than that?
Old 02-22-2005, 02:46 PM   #22
Purehell was urs the one in the picture? cause that has only 150 Hp stock if its a 1998 so my 99 should be quicker than 16.4
Old 02-22-2005, 03:07 PM   #23
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
The Wrx has a crapload more than 217 HP... I've ridden in one stock... those things are fast
That and with about $1200 you can get about 300 or more to the wheels and thats with the stock turbo... My friend has one and I help him mod it.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 02-26-2005, 09:37 PM   #24
Send a message via AIM to SeadudeRXP
I don't know about you guys but I have an 03 5-speed and I ran a 15.8 @ 89 at the track when I went, and my launch was terrible. I heard that guys with good launches can get as low as 15.3.
SeadudeRXP is offline   Reply With Quote
Old 02-27-2005, 11:24 AM   #25
There are a lot of factors. Sometimes location is just the biggest thing. People on the East coast run faster times than we do on the west coast too, generally. I've seen a whole second difference at different tracks, so thats why there are always so many arguements about time and such.
what elevation are you?
Old 02-27-2005, 08:53 PM   #26
timpryor's Avatar
I run CONSISTANT 16.18-16.20's at 85 MPH at 700Feet above sea level. Thats spinning too. My best time is a 16.06 @85.88
If I could get some decent tires and shave a few #'s I could hit 15's
the best thing that will get you times is PRACTICE.
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 02-28-2005, 02:29 PM   #27
Your best is .4 faster than my best.
Old 02-28-2005, 02:50 PM   #28
It's all about knowing your car & track conditions, the ability to adjust will get you good times.
Also elevation, Barometric pressure, Humidity & air temp can make huge differences.
2000 Vert 4R70W
Old 02-28-2005, 03:41 PM   #29
You missed my point.... You start off with 40 more horses than I do
Old 02-28-2005, 04:28 PM   #30
old post...?
Old 02-28-2005, 04:32 PM   #31
My comment was not aimed at anyones times in general.
I was a statement of variables most people don't realize make the biggest difference in their times or in comparison to anothers.
2000 Vert 4R70W
Old 02-28-2005, 05:45 PM   #32
Ahh. Since you posted it right after I posted the difference, I thought you wre referring to my times specifically.... my bad
And This is just an ongoing thread spector.
Old 02-28-2005, 06:32 PM   #33
ah ok, just thought she was pretty old.
Old 02-28-2005, 06:41 PM   #34
I've seen far worse!
Old 02-28-2005, 07:28 PM   #35
timpryor's Avatar
yeah those 40 horses will make a difference, and not trying to brag but i'm a pretty good driver. The other V6's out at the track were running 16.5's all night
Quarter window NC8950 1979-1995 Mustang GT 3 09-25-2006 03:45 PM
I Need to know the quarter mile time of my opponet TexaStang Pre-2005 V6 Mustang 27 07-25-2005 02:58 PM
estimated quarter mile time Sublime782 Pre-2005 V6 Mustang 5 07-08-2005 10:28 AM
Quarter mile time for a stock 98 v6 danstang Pre-2005 V6 Mustang 16 06-30-2005 06:22 PM
14.3 quarter mile @97.3 mph 5psi stock everything else jedwards242000 Pre-2005 V6 Mustang 16 04-10-2005 07:41 PM
01:48 AM
