new shifter for Auto V6? - Mustang Evolution
Old 05-14-2009, 09:52 AM   #1
The Darkside's Avatar
Ok i came accross this in a new issue of i think fast fords......i just looked it up. it looks Awsome but can somone explain to me the advantage of having this shifter......what it does, how it makes it easier to shift.
Thanks, i thought people would find this intresting.
http://http://www.tciauto.com/Products/Ford/5R55S/
http://http://www.rpmoutlet.com/05gtmacc.htm
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 05-14-2009, 09:58 AM   #2
Re: new shifter for Auto V6?
Fixed your links for you.
Also, I would avoid RPM outlet for anything you even dream of buying. Major pieces of crap over there.
Old 05-14-2009, 10:48 AM   #3
just putting a shifter on wont do anything for performance~ its just a shifter
Old 05-14-2009, 12:51 PM   #4
not performance wise, if you read the discription you see somthing about shifting being easier, somthing you can not do with the oem shifter......any idea?
im thinking they mean its easier to shift 1 2 3 and d.......what do you think?
i bleed Race fuel!
Old 05-14-2009, 01:00 PM   #5
I'm thinking they are looking for the suckers that would believe a different handle would make it easier to slide the shifter forward and backward.
But no, I don't see how they could make it easier for much of anything...it just looks prettier.
Old 05-14-2009, 05:05 PM   #6
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
i'm not sure, i might be missing something, but ratchet shifters basically turn your automatic into almost a manual. you put it in 1st, than of course it will stay in that gear till you change it, yes you can do this with the normal shifter, but on the ratchet ones you basically pull the ratchet and it goes directly into 2nd, which doing quickly otherwise might result in passing the gear you need. (thats what i've been told ne way, and again, i dunno which shifter exactly your talking about, but if it is the ratchet ones, there you go)
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 05-14-2009, 08:52 PM   #7
Yah, I'm seeing it as bloodyspirit058 is, as a ratchet shifter. If that is the case, I'd go with a B&M ratchet shifter if they make them for the 05+. I've heard good things about the 99-04 ones.
Old 05-15-2009, 07:56 AM   #8
intresting.....so it just makes shifting a bit easier and basicaly looks pretty lol is that the concensus?
i bleed Race fuel!
Old 05-15-2009, 09:18 AM   #9
you shouldnt manually shift your auto anyway not the one in your car from the factory at least
Old 05-15-2009, 12:26 PM   #10
so is it ok to shift in with this new shifter???
i bleed Race fuel!
Old 05-15-2009, 04:33 PM   #11
Region: Oregon
dunno about how safe it is or anything, bascally you pull the handle and it goes straight to second. the ratchet mechanism is put so it clicks into second, where normally when you put it into gear you can easly slide "through" the gears this just locks it than you just do it again and your inthe next gear, you can also hold some lever or w/e and it operatates just like a stock shifter. a guy at my last job talked about em a lot, he wanted one for a 70 somethin camaro.
from what i can tell (and my limited knowledge of auto transmissions since i don't like driving them) is that the transmission will shift before the rev limiter, how far, i have no clue, but for drag racing i guess its enough of a difference that this will benifit you.
on a side note, just remember not to shift in reverse when going 30-40 mph, my buddy did this in an expedition... we stopped pretty quick
Old 05-15-2009, 05:44 PM   #12
RyansQuick6's Avatar
manually shifting an auto is pointless, the computer is faster than you are and knows when to shift better. uif you want better shifts, but a tuner and shift kit.
RyansQuick6 is offline   Reply With Quote
Old 05-16-2009, 08:29 AM   #13
rinfield2004's Avatar
Dude, its completely ok to manually shift your 5r55 auto trans....just don't make it habit of doing it everyday. I've got an 01 v6 auto, upped the shift pressure, and manually shift it racing and on occassion. I haven't had a lick of problems out of it in the 4yrs I've had my car. About the shifting thing, just pay attention to when and where you shift you shouldn't have a problem missing a gear. Key is, pay attention.
rinfield2004 is offline   Reply With Quote
Old 05-16-2009, 06:00 PM   #14
BIGBLOCKTRADER's Avatar
BIGBLOCKTRADER is offline   Reply With Quote
Old 05-20-2009, 09:58 AM   #15
lol i kinda agree with this as much as i like this product lol i mean i guess a shift kit would be more benificial.
but the shifter just looks nice for an automatic lol
i bleed Race fuel!
Old 05-20-2009, 10:04 AM   #16
thats hot!
i bleed Race fuel!
Old 05-20-2009, 10:07 AM   #17
Originally Posted by Ken Cheema View Post
thats hot!
i bleed Race fuel!
Old 05-20-2009, 07:40 PM   #18
upton7's Avatar
i didn't think they made shift kits anymore i thought the tuners did everything
Old 05-21-2009, 08:44 AM   #19
nope ive been told several times to get a shift kit........i dont get it cause of my wife, if her head hits the head rest anymore then it already does shell kill me! lol
i bleed Race fuel!
Auto shifter boot RedDragonV6 Mustang Audio & Video 3 03-01-2004 04:26 PM
02:16 PM
