license plate lights - Mustang Evolution
Old 05-15-2009, 09:41 PM   #1
how i change the 2 bulbs of the license plate??
carlosc is offline   Reply With Quote
Old 05-15-2009, 10:34 PM   #2
upton7's Avatar
Re: license plate lights
never have but if it is a 99-04 i'd see if there were screws hodling it in then i'd check inside the trunk
Old 05-16-2009, 12:40 AM   #3
OsirisGuy's Avatar
While other body styles might vary, I'm definitely sure the SN95 (1994-2004) have two plastic screws per light. Pop the trunk and look above the license plate and you will see those screws. They will be a PITA so what you will have to do is get a small flathead screwdriver, or a small pick tool, and separate (pry) the screw from the plastic base. It will be hard to see but underneath the screw is a plastic base it actually screws into, when the screw is screwed in it will expand the plastic base holding the light assembly to the car.
By putting leverage between these two, and unscrewing the the philips head you should come out fairly easy. You just need a little patience with the whole procedure and fool around with it.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 05-17-2009, 01:26 PM   #4
CrzyBeautiful's Avatar
Send a message via AIM to CrzyBeautiful Send a message via Yahoo to CrzyBeautiful
^^^ <---- right on the money
I had to change mine the other day and to my surprise I also saw that the casing was cracked - so when you remove them you have to be very careful because those little lights are delicate. The bulb to be used is 168. If you use any other size you run the risk of causing a short. I have seen it happen... But other than that the whole process should take you no more than 5-10 minutes. Its pretty painless!
Good luck!
CrzyBeautiful is offline   Reply With Quote
License Plate Lights redone88 General Mustang Discussion 1 11-18-2008 11:57 PM
License Plate Bama Matt Mustang Audio & Video 11 04-18-2006 02:40 PM
front license plate red pony V6 Mustang Audio & Video 5 05-04-2005 04:30 PM
license plate ideas?? Falcon The Bar 13 11-09-2003 08:33 PM
License plate Falcon The Bar 3 11-09-2003 11:34 AM
10:21 AM
