bell type - Mustang Evolution
Old 02-01-2005, 06:46 PM   #1
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
bell type
ok i if I buy a 1965-69 stang with a 289 is it possible to match a t-5 up to it? and how hard would it be to put a newer 5.0 a matching t-5 and a costume drive shaft and rearend in too it? i mean i kno it would be alot of work but i dont think it would be overly hard. 64 im looking for you input. thanks for the help
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 02-01-2005, 08:00 PM   #2
your gonna have to talk to fast 64 about that one
btw im looking in to it (doing some searches)
Old 02-01-2005, 09:01 PM   #3
Originally Posted by rbohm
the swap is quite simple. mustangs plus sells driveshafts for the swap, and if you dont mind converting to a cable clutch, you can use a late model 5.0 bellhousing. if you want to keep your stock clutch linkage(you are a fool if you do so in my opinion) then you just need a top loader to T5 adaptor plate. as far as the clutch is concerned, you can use the long style pressure plate(if you are keeping your stock linkage), and use a disc for the
T5.
found this on another forum
Old 02-01-2005, 09:13 PM   #4
check this http://www.2mfffabshop.com/rod.htm
Old 02-02-2005, 04:22 PM   #5
^ man with the info. i think this could be beast, a 60s modded 289 running though a 5 spd with a set of disc brakes.
Delta Sigma Phi
www.DeltaArmsCo.com
Old 02-02-2005, 04:40 PM   #6
go for it man
Procharger or Kenne Bell? MonteCitan 1996-2004 Mustang GT 15 11-08-2009 12:42 PM
Kenne Bell oaktonarcher 1996-2004 Mustang GT 5 07-10-2008 10:26 AM
trans and bell white95v6 Mustang Parts for Sale and Wanted 0 04-03-2005 09:58 PM
DAMN yOU TACO BELL!!! Zim The Bar 16 05-19-2004 09:30 AM
07:33 AM
