Battery light comes on under hard acceleration - Mustang Evolution
Old 02-01-2005, 10:46 PM   #1
If I am at a red light and I floor it it jerks forward and the battery light comes on for about a second then goes off..... and my top end hp sucks bad......
What do you guys think? Bad belt, warped pulley... alternator going bad? Anyone seen this happen before?
Old 02-01-2005, 11:16 PM   #2
Tbird232ci's Avatar
first, check your battery cables, as much of them as you can find, a bad ground could cause issues, if they look good, have your battery tested at advance
you could put your volt meter on your battery all day, and read 12 volts, but a load test is what really tests the battery
if the battery checks out, have the alternator tested (has to be removed to do so), and if thats not the issue, then i dont know what is
Old 02-01-2005, 11:18 PM   #3
Um....don't floor the poor thing...lol.
BTW, check out the sig quote...
Old 02-02-2005, 07:36 AM   #4
I would put a fresh belt on it, do you have an UD pulley?
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 02-02-2005, 09:04 AM   #5
Dom
Dom's Avatar
Send a message via AIM to Dom
Yea, it's probally the belt slipping.
Old 02-02-2005, 12:41 PM   #6
No UD pulley.
How much are belts?
Old 02-02-2005, 01:33 PM   #7
Its usaully between $15-$30 if you go to a place like Auto zone.
Jason Starkey
2006 Vista Blue 4.0 Mustang
www.VMPTuning.com - SCT Chips, Flashers, and Dynotuning.
Phone: 321-206-9369
Email: Jason@VMPTuning.com
JasonVMP is offline   Reply With Quote
Old 02-02-2005, 01:38 PM   #8
Thanks I will try that and see if it helps. Could a alternator going bad cause this or no? When I am backing out of my driverway sometimes and put it from reverse to drive it stalls out... doesnt do it everytime though.... the rpms do drop very low as if its about to die though most of the time.
I have a extra alternator I can put on from a low mileage engine if the belt isnt the problem
btw can you take a look at this video I made and give me your .02 worth of what you think it is http://mustangevolution.com/forum/sh...ad.php?t=10362
Old 02-02-2005, 02:00 PM   #9
I liek gramer
WhiteStang99's Avatar
no idea brent, but
LMFAO AT BRAD'S SIG!!!!!!! bahahahahhahahaha.
Old 02-02-2005, 08:31 PM   #10
Dom
Dom's Avatar
Well try the belt first. That takes the whole five minutes to install, and if it's not that, order one of those polished alternator casings from Rob ( :thumbs2: ) and take it to some old timer and let him rebuild it. It's not about volts on an alternator, it's about amps.
Old 02-02-2005, 08:40 PM   #11
I have a extra alternator I can use.
Old 02-02-2005, 09:20 PM   #12
Fishers Stang's Avatar
yeah like that Brent?
Charles
Old 02-02-2005, 09:27 PM   #13
^ That is the exact same thing mine does
Old 02-02-2005, 11:05 PM   #14
alternators are pretty easy to change
Old 02-02-2005, 11:06 PM   #15
fvck what did i just put my self into....
Old 02-02-2005, 11:09 PM   #16
I liek gramer
^ lmao
Old 02-02-2005, 11:34 PM   #17
232stang01's Avatar
Send a message via AIM to 232stang01 Send a message via Yahoo to 232stang01
correct me if I'm wrong, but if you were to put a voltmeter to a battery, it should read closer to 13 volts, right?
232stang01 is offline   Reply With Quote
Old 02-04-2005, 09:46 PM   #18
^ no clue but I am replacing the alternator as we speak so I'll see if that fixes it.
Old 02-04-2005, 11:18 PM   #19
12.6
Old 02-05-2005, 12:12 AM   #20
Alternators changed... to drunk to drive it so it will have o wait tioll tomoroow to test eit oit
Old 02-05-2005, 12:30 AM   #21
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 02-05-2005, 09:15 AM   #22
woot
Old 02-05-2005, 11:53 AM   #23
Well it looks like it fixed it... but we will have to see after more driving around
Old 02-05-2005, 03:18 PM   #24
Well the damn ground screw on the alternator I put on borke and I cant ground the thing. So now i got to put the old alternator back on tonight
battery light blackonblack Pre-2005 V6 Mustang 17 01-20-2010 09:22 PM
Battery light? runvsofthisbull Pre-2005 V6 Mustang 6 06-22-2009 07:02 PM
battery light carlosc Pre-2005 V6 Mustang 4 09-18-2007 09:34 PM
Battery Light megax29 Pre-2005 V6 Mustang 1 06-20-2007 03:11 PM
Battery Light fordfan1184 Pre-2005 V6 Mustang 2 08-27-2003 03:16 PM
04:34 AM
