abs and trac control light. - Mustang Evolution
Old 05-18-2009, 07:02 AM   #1
My wifes 02 mustang had the abs light pop on and then go off for a couple weeks and not its on all the time and now when its on the trac contol is off and you can't turn it back on. I have a abs code reader but for some reason it will not read her mustang, just wondering if anyone else has had a problem like this and if so what the problem was. Thanks
powerstroker is offline   Reply With Quote
Old 05-18-2009, 08:06 AM   #2
RyansQuick6's Avatar
Re: abs and trac control light.
Most likely a bad sensor on one of the hubs. An OBDII code-reader might give you a little more insight. take off each wheel and inspect the sensor and the tone ring first.
RyansQuick6 is offline   Reply With Quote
Old 05-20-2009, 07:30 PM   #3
rinfield2004's Avatar
my t/c light is on, but thats due to my tuner permanently turning it off in the computer. and my abs light is on due to me accidently knicking the abs sensor (lol) on the hub during my gear swap install. So uh, whatever thats worth, just my 2cents.
rinfield2004 is offline   Reply With Quote
Old 05-21-2009, 12:56 PM   #4
SaleenFiend's Avatar
Not just any OBD II Scanner will read ABS issues. I would bring it to a local reputable shop or a buddy that has the knowledge/equipment to read it.
Check your battery, a lot of times a low voltage code can set and cause other Vigilante codes that aren't real.
AbS light 2000StangLover Pre-2005 V6 Mustang 2 09-02-2008 01:44 PM
Brake Light & ABS Light on. stevinas 2005-2010 Mustang GT 1 06-26-2008 02:21 PM
ABS light slick Pre-2005 V6 Mustang 5 04-04-2008 11:31 AM
ABS light Zim 1979-1995 Mustang GT 9 10-13-2006 06:25 PM
ABS and Traction control light on rugman1969 1996-2004 Mustang GT 1 09-30-2006 03:09 PM
02:02 PM
