4:10 gear help - Mustang Evolution
Old 05-18-2009, 08:05 AM   #1
The Darkside's Avatar
4:10 gear help
Hey guys, so i got my car back, but my "awsome" mechanic forgot that he needs to retune the car for the new gear ratio. so i feel like it shift from 1 2 3 all by 30 miles per hour. im sure this is not correct.
on thurs i will go back and he will correct this problem. My question is can somone discribe to me
1)hows its supposed to shift,
2) approximatly what MPH into what gear
3) why my car feels so much better once i hit 60?
4) is my speedometer off because it says im going 80 and i feel like 65.
thank you again for all your help guys. i dont know what id do with out the crew of mustang evolution!
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 05-18-2009, 08:19 AM   #2
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Re: 4:10 gear help
4) if they didn't change the speedsensor pinion gear thingy to try to readjust your speedo closer to what its actually doing than it will be way off, specially with 4.10's
don't know any of the otherones... sry
on a side note, you will be in higher rpms at every speed. for example doing 65 i'm right about 1500 rpm in 5th, if i switched to 4.10's it going to be around 2300. i'm sure you already knew this since you did go with the gears, i'm mostly saying it because it might have something to do with that "feeling" of going one speed and feeling another (if your speedo is correct)
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 05-18-2009, 09:13 AM   #3
Re: 4:10 gear help
thanks for the info. every bit helps!
i bleed Race fuel!
Old 05-18-2009, 09:26 AM   #4
Re: 4:10 gear help
Yes, your speedo is off. They need to update the tune to let it know you have 4.10's now. It's all electronic these days. You used to swap out a speedo gear based on what rear gears you have.
As for the rest, your current tune is setup up to shift at certain RPM's in each gear. Because your 4.10's are putting you in higher RPMs at every speed, the computer is shifting much earlier than it needs to or that it thinks it should. After 60, the car probably feels better because your tune wants it to be in the higher gear and the car is actually wanting to be there as well. So around 60, you tune and your car are both happy. The other gears, you're way down in your power band so it is not as happy.
I wouldn't be romping on the car too much until you get the tune updated. It probably won't hurt anything to, but, I would just rather run the car where it shifts where it wants to and not bouncing all over trying to up and down shift in weird spots.
Old 05-20-2009, 09:20 AM   #5
Re: 4:10 gear help
Always got the anwser for me! you rock! thanks. im going tommrow to get the new tune put in, ill let you know how it drives after
i bleed Race fuel!
Old 05-20-2009, 04:30 PM   #6
Region: Oregon
Re: 4:10 gear help
good to know, not to familiar with the new stuff, i just knew the gear thing for the older ones.
Old 05-20-2009, 04:38 PM   #7
Re: 4:10 gear help
They always need to make things more technical under the guise of "making things easier".
Old 05-27-2009, 01:24 PM   #8
Re: 4:10 gear help
venom i have a question. my car is shifting fine now, the car feels like a freaken beast, actually got a little scared on the highway when i punched it cause i could feel the loss in traction lol
but i sware that the speedo is still wrong. i feel like it shows 10 mph more then it actually is. any suggestions.
the retuning was done telling the car that it has 4:10 gears.
i bleed Race fuel!
Old 05-27-2009, 01:52 PM   #9
Herbstang's Avatar
Re: 4:10 gear help
Don't switch gears these days it all electro For so reason tuner seem to have problems with the 4:10 and 3:73
HELP!! gear problem blackonblack Pre-2005 V6 Mustang 15 12-30-2009 09:03 PM
96 4.6 will not go into fifth gear duals 1996-2004 Mustang GT 10 09-05-2008 11:06 PM
Gear oil really does .... ... ... MonteCitan The Bar 9 04-20-2005 07:34 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
05:41 PM
