Under Drive Pulleys - Mustang Evolution
Old 05-24-2009, 01:02 PM   #1
2007STANG's Avatar
Region: West Virgina
Question Under Drive Pulleys
Hay all. for My V6 2007
was looking on net (moss, american, steeda ect.) for under drive pulleys and the only thing i could find is (underdrive crank pulley/harmonic damper assembly) is that all that is out there.
2007STANG is offline   Reply With Quote
Old 05-24-2009, 02:04 PM   #2
hottcobra's Avatar
Re: Under Drive Pulleys
I guess the V6 cars don't need a larger waterpump pulley.
Old 06-01-2009, 10:09 AM   #3
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I've got an ASP underdrive pulley. 20% underdrive, I believe, and I've never had any overheating problems on the road or track. Just the harmonic balancer and crank pulley are all that's required.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Under drive pulleys question mk70ss 2005-2010 Mustang GT 1 07-30-2010 10:14 PM
Just installed my under drive pulleys! SickGT 2005-2010 Mustang GT 8 07-07-2010 10:08 AM
Pulleys! gasteven Pre-2005 V6 Mustang 16 04-15-2010 11:25 AM
Pulleys SaturnMan8227 Pre-2005 V6 Mustang 12 01-19-2009 02:18 PM
Under drive pulleys, should I or shouldn't I? microflight 1996-2004 Mustang GT 32 07-30-2007 12:31 AM
01:17 PM
