drop top Rob - Mustang Evolution
Old 05-25-2009, 08:04 AM   #1
drop top Rob
Can any one tell me if I can install a 3.8 liter engine from a 2000 mustang into a 1995 mustang. this car is already equiped with a 3.8 however I have been told the swap can't be done. I have a problem with this, it seems to me the only hindering factor would be sensers.
drop top Rob is offline   Reply With Quote
Old 05-25-2009, 10:59 AM   #2
hottcobra's Avatar
Re: drop top Rob
well the wiring and control systems are the only thing that is tuff. youneed to try to find a complete engine wiring harness and ECU for the new engine.
Old 05-25-2009, 07:47 PM   #3
upton7's Avatar
Re: drop top Rob
Did you blow it up?
Old 05-26-2009, 08:56 AM   #4
Re: drop top Rob
it can be done and has been done. It is not a direct drop in and go. You will need a new wiring harness, computer, fuel lines and fuel tank (the fuel return system differs), and other this and thats~
you could port your heads/intakes and do a good cam setup and make more hp/tq than a 99+ 3.8L if you wanted
Old 05-26-2009, 10:46 AM   #5
Re: drop top Rob
the fuel system is different and will have to be replaced to 99 up specifications as well
ok, so Rob (purevenom) was right... SimplyOrange The Bar 45 11-04-2008 09:57 PM
Don't rob someone with an H1 PureVenom Pictures and Videos 2 02-09-2007 05:27 PM
03:04 AM
