Single Port ---> Splitport Parts needed - Mustang Evolution
Old 02-09-2005, 10:19 PM   #1
Alright guys I need a list of what I need and where to get it.
I want to do it right.
I know I will need the Intakes and Heads and to convert to returnless fuel system.
What fuel parts and other parts will I need and where can I buy them from and prices?
Old 02-10-2005, 06:26 AM   #2
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
*watches thread*
i want to do this eventually too
@ 4.2 strokers
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 02-10-2005, 08:14 AM   #3
im getting ready to do it heads, intake manifolds tb, maf, throttle cable, cruise cable, fuel injectors, specially made fuelrail, and i dont think anything else im also going to upgrade the fuel pump but dont think you need to
hawks05 is offline   Reply With Quote
Old 02-10-2005, 08:21 AM   #4
Danger Dude's Avatar
You will also need the bracket to relocate the coilpack ,new plug wires and you will need either a stock Air intake setup or a CAI or you could go get a 2002 complete motor for $750 with 1 year warranty then all you would need is a modded fuel rail.
Old 02-10-2005, 08:23 AM   #5
or you can get it all for as cheap as i did and get it all p&p for less than that motor cost just have to keep your eyes open for good deals
Old 02-10-2005, 08:28 AM   #6
There is a time factor here his car needs fixing soon and he might not have the time to wait for deals.
Old 02-10-2005, 03:43 PM   #7
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I'm selling some split port stuff in the for-sale Section. The heads and lower intake would be identical to the mustang ones.
4.2 split port engine parts/torque converter/steeda parts
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
single port or split port 97 stang Pre-2005 V6 Mustang 8 10-10-2008 06:51 PM
single port to split port conversion NorwegianMustang Pre-2005 V6 Mustang 3 06-19-2006 03:19 PM
5.0 TB to Single Port TB adaptor TheSarge Mustang Parts for Sale and Wanted 2 11-13-2005 10:55 AM
My terminology for single port and split port RGR Pre-2005 V6 Mustang 0 01-03-2004 10:03 AM
02:21 PM
