Best shocks and struts for lowered stang. - Mustang Evolution
Old 05-26-2009, 11:16 AM   #1
My wife wanted her 02 lowered,so we dropped it two inches. Was wondering what everyone is running for shocks and struts on their lowered cars to get the best ride possible being lowered. Thanks
powerstroker is offline   Reply With Quote
Old 05-26-2009, 01:52 PM   #2
Re: Best shocks and struts for lowered stang.
for the best ride the struts/shocks will have to be valved the same or in a given range to "match" up correctly.
Did you cut the springs or did you replace them with aftermarket ones? You will need to know the spring rate before you can determine what shocks/struts will work best.
Also you will need caster camber plates, I recommend maximum motorsports 4 bolt design as they allow more adjustment for alignment specifications as well as they allow the strut shaft to come back up higher to offset the lowering effect on the strut shaft.
The lowering effect is as you lower the the car the top of the strut shaft cant go up higher with the stock caster/camber plates so more of the strut shaft is pushed into the strut all the time vs before the car was lowered. This over time can wear out the strut and will wear it out faster.
By allowing the strut shaft to come back up some you help offset this issue, its not some massive issue just something to be aware of as you will need a way to align the car anyway so this can do two things at once for you.
Tokico blue's work good or Mach 1 specific tokicos for springs with a rate 500-600~ and are usually under 200 a set of 4.
Old 05-26-2009, 04:04 PM   #3
It was an eibach kit, the car already has caster/camber plates, it was lowered about an inch before with ford racing springs, she just wanted to go lower.
Old 05-26-2009, 04:07 PM   #4
im running kyb's with my eibach kit and it rides real good.
96 GT- Who knows what's in it.
Old 05-26-2009, 10:28 PM   #5
upton7's Avatar
I got tokico d-specs full customize and i hate em
Old 05-27-2009, 12:12 AM   #6
OsirisGuy's Avatar
Many people say Bilsteins are the best. They are good shocks and struts especially for an overall ride (not for drag though). They are on the expensive side and will most likely be what I will get when I have the extra cash.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Struts and Shocks xcxm049 Pre-2005 V6 Mustang 11 03-05-2010 12:59 PM
shocks/struts Sublime782 Pre-2005 V6 Mustang 15 05-15-2007 01:06 PM
shocks and struts all8280bcc 1996-2004 Mustang GT 8 03-01-2007 12:49 PM
Shocks Struts megax29 Pre-2005 V6 Mustang 11 07-12-2006 09:34 PM
Shocks..struts Exit_In_Red Pre-2005 V6 Mustang 6 12-01-2004 10:33 PM
04:03 AM
