94 v6 tuner info - Mustang Evolution
Old 05-27-2009, 01:05 AM   #1
94 v6 tuner info
i am new to this site and i would like to know if should go to a custom tune shop or order a handheld myself.it does have a stroked 3.8 p/p heads&intake,cai,true dual exhaust,underdrive pullies,forged pistons,rods.just want to know what will be the best way to tune the ecu.thanks
smokin six is offline   Reply With Quote
Old 05-27-2009, 01:28 AM   #2
upton7's Avatar
Re: 94 v6 tuner info
You'll have to buy a handheld tuner either way. And how is it a 3.8 if it is stroked?
Old 05-27-2009, 01:36 AM   #3
do you have any expirience with a handheld for a v6 what things can i change or adjust. and i meant to say bored 3.8
Old 05-27-2009, 01:52 AM   #4
upton7's Avatar
you can clear and read trouble codes. Adjust shift points. Tune for higher octanes. When it gets dyno tuned they will load it onto your handheld tuner. And save your stock one in case you ever want to go back in case you sell it or something and you can tune for new upgrades.
Old 05-27-2009, 01:56 AM   #5
do they work for speed and rev limiters on this car or how about rear end gears would the tuner cover that
Old 05-27-2009, 02:03 AM   #6
upton7's Avatar
They fix speedometer for gears and larger or smaller whels they raise the rev limiter and they will boost horsepower. With a good dyno tune i wouldn't doubt you'd get over 15 rwhp
Old 05-27-2009, 02:07 AM   #7
so if i were to buy one lets say a sct i will have to go to a dyno shop to be able to tune or i can just plug and pick what i want or when i order it will i have to say the mods that aer done to the car. i appriciate your response.
Old 05-27-2009, 02:12 AM   #8
upton7's Avatar
You can get an sct x3 from american muscle and they will give you an "off the shelf tune" those won't get you much horsepower. If you go get a dyno tune it will be specifically for your vehicle and the horsepower increase will be much better but you don't have to get an sct brand but i would recommend it.
Old 05-27-2009, 02:19 AM   #9
i appricite evrything on the tuner,but can i also ask your opinion on x or h pipe on a v6 when i had my exhaust done last week they made a custom x pipe wit flowmasters and dynomax mandrel tail pipes do think the x was a good idea i like the way it sound but how on the flow and performance end.
Old 05-28-2009, 03:38 PM   #10
Otlaw80's Avatar
I believe the x-pipe would flow a little smoother, just because of the design. Prob not a noticable difference compared to an H though. As for the tuner, it will remove/raise the speed/rev limiter, but it will not do anything for your speedometer on a 94-95, from what i understand. You will have to get a new speedo gear to match whatever ring & pinion ratio you put in.
Old 05-28-2009, 09:40 PM   #11
I've heard good things about VMP tuning. They do custom SCT tuning for v6 mustangs. I almost wonder if it would be just as good to make custom tunes through them. They would probably take all the bored engine components into consideration.
You could buy the tuner and plug n' play to free up some hp, but a good dyno tune at a reputable shop will gain the most power for your car.
Old 05-29-2009, 07:48 AM   #12
SaleenFiend's Avatar
James RWTD will give your free custom tunes when you order a Diablo Sport Handheld Predator Tuner. You give him a list of your mods. It would be better than the can tunes...
Running With The Devil
tuner help soccerfreak2143 General Mustang Discussion 5 08-06-2010 07:41 AM
tuner upton7 1996-2004 Mustang GT 13 02-21-2010 08:37 AM
Which Tuner to Get? mxw1090 Pre-2005 V6 Mustang 5 06-19-2009 11:46 AM
Tuner GT773 2005-2010 Mustang GT 12 06-16-2009 02:41 PM
Why get a tuner? Laser 1996-2004 Mustang GT 10 06-11-2007 07:31 PM
08:31 AM
