Another Exhaust Question - Mustang Evolution
Old 08-01-2003, 09:36 AM   #1
I know there are plenty of Exhaust questions on this forum, but I haven't found an answer to my question. I am going to put a Flowmaster Force II CAT-Back system on my car. What I haven't decided on yet is if I should use the recommend kit for the 3.8L which as a reverse 'Y' pipe bolt-on or get the GT kit and make a custom 'H' pipe so it is a true dual pipe. Skill wise I am fine either way, what I am concerned about is if I make an 'H' pipe, will I loose all my back presssure and therefore loose my low end torque? The recommend kit uses 2.25" pipe and the GT kit uses 2.5" pipe.
Thanks,
Mike
'03 Mustang Coupe, Auto, K&N Air Filter, MACH 460 Stereo, JL Audio 10W0 Sub, JL Audio e1200 Amp, 35% Tint
http://www.oraucoc.org/downloads/mwi...tangbanner.jpg
TriStateStang is offline   Reply With Quote
Old 08-01-2003, 11:22 AM   #2
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Use 2.25 piping and you will regain most back pressure.
You can get the Y pipe adapter kit. But those kits are not true duals. They come with minimal gains. Like +1-3 hp.
True duals such as 2 straight pipes, or an H pipe will loose a 'little' backpressure but not much if you stay with 2.25 piping. You may not even notice it.
Also with true duals. You will see higher gains as you start modding your car since they exhaust will flow better.
Rellik is offline   Reply With Quote
Old 08-01-2003, 01:18 PM   #3
Send a message via AIM to el cheapo
what he said
damn it school, why do you suck so bad??
el cheapo is offline   Reply With Quote
Old 08-01-2003, 02:59 PM   #4
all stock gt and v6 exhaust pipe is 2.25 inches in diameter. run that and you wont have a problem if you go true dual.
exhaust
Question on exhaust jdl0812 General Mustang Discussion 25 04-01-2010 10:25 AM
exhaust question? roach 1996-2004 Mustang GT 3 12-21-2006 12:18 AM
new here and got an exhaust question ~Lesly~ Pre-2005 V6 Mustang 18 06-17-2006 12:16 PM
Exhaust Question The Arson Pre-2005 V6 Mustang 1 09-12-2004 08:57 PM
exhaust question(s) mexor Pre-2005 V6 Mustang 8 08-01-2003 03:01 PM
04:26 AM
