HOW???!!! - Mustang Evolution
Old 05-28-2009, 10:24 AM   #1
HOW???!!!
It seems like a simple operation, but HOW do you take off the dipstick?
I have an 01 v6, and i have the bracket off but it seems stuck, please help.
Thanks will be given
mrjones3133 is offline   Reply With Quote
Old 05-28-2009, 10:40 AM   #2
Re: HOW???!!!
It should just pull up out of the block. You may have to wiggle/twist it back and forth as you pull up, but it should just pull right on out. At least, that's what it did on an 02 V6 I worked on.
Old 05-28-2009, 10:49 AM   #3
DarkShadows's Avatar
Re: HOW???!!!
bout to say it shouldnt be a hard process, not that ever understood why ford made the dipstick all fed up like that
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 05-28-2009, 12:25 PM   #4
SaleenFiend's Avatar
Re: HOW???!!!
Because they can...
Old 05-28-2009, 12:25 PM   #5
upton7's Avatar
Re: HOW???!!!
I tore apart a chevy small block yesterday and i had it on an engine lift and i had to pull hard and twist it around a bit so i'm guessin if you are just workin under the hood it will just be harder to pull.
Old 05-28-2009, 02:41 PM   #6
Re: HOW???!!!
some bolt to the header~ so check to see if its bolted on somewhere
Old 05-28-2009, 02:53 PM   #7
Re: HOW???!!!
Originally Posted by SaleenFiend View Post
Because they can...
great answer to you
Old 05-28-2009, 02:58 PM   #8
Re: HOW???!!!
I can't comment on this or not because the 02 I worked on had shorty headers installed previously...so I don't know if they may have left off part of the tube or not.
But, the car I worked on just had the tube bolted to the block up high and then pushed into the block down low.
05:52 PM
