Exhaust ? - Mustang Evolution
Old 05-30-2009, 05:59 PM   #1
2007STANG's Avatar
Region: West Virgina
Exhaust ?
Whats better "H" "y" "X" or true Duel, pipes for a 2007 V6 duel set up.
2007STANG is offline   Reply With Quote
Old 05-30-2009, 06:49 PM   #2
Re: Exhaust ?
Well, from what i've heard, the h-pipe doesn't really matter to us since we have an even firing engine, though it will keep the exhaust from getting too raspy.
An x-pipe will probably make whatever exhaust tone you have pretty raspy beyond 2500rpms. Despite this, a lot of people use them on v6's.
The y is just the stock adapter that converts the two catted pipes down to one single pipe. You can buy a converter back system that bolts right up to the y-pipe. These aren't the best systems, but they are okay if you want better sound and looks.
Two straight pipes (true dual) will make the v6 sound bad. No cats will make it too loud and obnoxious. I wouldn't recommend it. The best sounding sixxer is a quieter, more mellow sounding sixxer.
Many people use the weld-in adapters, h or x-pipes, or the stock y-pipe.
Either way, I would keep the cats. Whether they are stock or high flow, I would have some kind of cats on. Paired with some good mufflers, you will have a decent sounding v6.
It's basically up to you. I've heard all the different options on v6's, the only one I wouldn't recommend is the straight pipe option.
Old 05-30-2009, 11:25 PM   #3
upton7's Avatar
Re: Exhaust ?
i got an x and i like it
Old 05-31-2009, 07:20 AM   #4
Greywolf's Avatar
Region: Nevada
Re: Exhaust ?
Really, you like your X? I can't stand mine, it's why I dumped her...
2007 V6 Mustang w/ Pony Package. Performance Mods - 2.25 custom aluminum catback exhaust with a Magnaflow muffler, AirRaid cold air intake, drilled and slotted rotor's front and rear, SCT Programmer, Ford Racing Tlok, Motiv 4:10 gears, LFP underdrive pulley
Greywolf is offline   Reply With Quote
Old 06-01-2009, 11:17 PM   #5
Re: Exhaust ?
you will get alot of differnt answer on this subject... here mine..... with our s197 v6 engine there is no real reason to add header or dual exhaust... u gain no a thing but you will spend a lot of money for not a thing.... i do remend that you remove the stock muffler and replace it... i am using a jba unit.. nice tone, not loud , has a nice sound to it. dual exhaust system can cost u up to 900 dollars... spend ur money on something that will give back hp!!!:
colorado pony is offline   Reply With Quote
Old 06-02-2009, 03:34 AM   #6
2007STANG's Avatar
Re: Exhaust ?
Thanks but I'm Trying to free up The Exhaust For Later MOD's I have a Pypes Axle back On it Now and it sounds Great. according to the Mod list to go turbo or NOS I need to Go to 2.5" exhaust is that correct??? I've found cat back for $450 on line
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
Old 06-02-2009, 07:05 AM   #7
Re: Exhaust ?
for a V6 you dont need a balance pipe the engine is even fire to start with, an H wont hurt anything but isnt needed.
exhaust
09:47 AM
