90 MM maf fitment question - Mustang Evolution
Old 06-01-2009, 09:21 AM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Does the 90 MM Lightning MAF have the same bolt pattern as the stock V6 MAF 99-04? My 4.2 is coming together and I've heard of guys running the 90MM on a v6 but I was hoping to get a heads up on how much work it will be fitting it to my CAI. Anybody got some info?
Thanks
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 06-01-2009, 10:52 AM   #2
Herbstang's Avatar
Re: 90 MM maf fitment question
the 90 MAF has 4" inlet and 4" outlet a adapter flange is required to attach the air filter the lighting MAF max out at 450 so if your going higher 90 you'll need MAF-extender It allows the MAF to remain high-resolution at low voltages so the car idles well
Old 06-01-2009, 11:13 AM   #3
Region: Iowa
I hadn't heard about any trouble with idle with the lightening maf. Thanks.
Old 06-01-2009, 11:42 AM   #4
Herbstang's Avatar
The connector you need for an LMAF is part number F68Z-12A690-AA or go to a junkyard.
17x10.5 wheel fitment question Evil J Mustang Wheels & Tires 4 10-30-2009 07:19 AM
69 tire and wheel fitment Indymustang Classic Mustangs 1 09-12-2006 08:25 AM
exhaust fitment Ponycarman Pre-2005 V6 Mustang 19 07-28-2005 07:15 AM
MAF Question Kiljosh Pre-2005 V6 Mustang 12 07-03-2005 11:14 AM
80mm MAF question... Tbird232ci The Bar 5 05-25-2005 11:26 AM
10:38 AM
