98 Ford Mustang Odometer issues - Mustang Evolution
Old 06-02-2009, 05:05 PM   #1
My Odometer stopped working ... the speedometer is fine as it marks the speed correctly, but the mileage and tripometer are stuck and no longer record my total vehicle mileage and trip mileage, what could this be? Do i need to replace the odometer entirely?
StreetJMusic is offline   Reply With Quote
Old 06-02-2009, 05:49 PM   #2
Re: 98 Ford Mustang Odometer issues
It could be a worn gear. Probably just easier to replace it. I know they had the kit at Late Model Restoration Supply for 24.95. You might be able to find them elsewhere cheaper. Maybe check your local ford dealer to compare prices.
Old 06-02-2009, 05:52 PM   #3
Replace the entire odometer? Thats about $500 aint it?
What do you mean by gear, the actual gear that turns the numbers?
Old 06-02-2009, 06:08 PM   #4
The 94-98's used an actual gear to turn the odometer numbers. The 99+ were all digital. Apparently there are two gears that wear out. A normal pinion-like gear, and a worm gear. Replacing those will get your odometer turning numbers again.
I don't have a 94-98, so I haven't replaced one before. I would imagine someone on here has. If anything, maybe the new kit will have instructions to install.
Old 06-02-2009, 08:53 PM   #5
GtrTech's Avatar
Heres a how to
Pictorial Guide To Replacement of Ford Odometer Gears
Replacement gears are about $25.00
The war is coming to the streets of America and if you are not keeping and bearing and practicing with your arms then you will be helpless and you will be the victim of evil.
Ted Nugent
GtrTech is offline   Reply With Quote
Old 06-03-2009, 08:25 AM   #6
SaleenFiend's Avatar
Simple as pie!
Old 06-03-2009, 10:37 AM   #7
Originally Posted by GtrTech View Post
Heres a how to
WOW, doesnt get any easier than that! Perfect!
odometer 98mustang2007 Pre-2005 V6 Mustang 2 03-28-2008 04:14 PM
odometer not working 98mustang2007 1996-2004 Mustang GT 4 03-20-2008 10:25 AM
What to do when replacing Odometer? fast64 General Car Discussion 5 01-17-2008 08:52 AM
What does your Odometer read? DarkShadow General Car Discussion 54 06-18-2007 09:53 PM
04:14 PM
