What gonna happen - Mustang Evolution
Old 02-21-2005, 09:28 PM   #1
OR_Red98's Avatar
Region: Oregon
What gonna happen
if'n I remove my EGR valve. The reason I ask is because I,m finally getting around to installing my phenolic isolator and I'd rather not fool around with the damn tube. Any help would be greatly appreciated.
Dennis........Retired USAF, Disabled Vet.
http://www.mustangmods.com/data/666/the_stang_005.jpg
Red "98" coupe V6 AT. Saleen boby kit, 18" replica Saleen rims, FMC "C" springs, Mach 1/Tokico shocks/struts, GT sway bars, GT STB, Sequential turn signals, Euro head lights and clear corners, BBK CAI and GT take-off exhaust.
OR_Red98 is offline   Reply With Quote
Old 02-21-2005, 09:30 PM   #2
you wont pass emissions and i belive youll get a MIL
Old 02-21-2005, 09:39 PM   #3
Thats about the jest of it. If neither of those is a problem go for it.
Old 02-22-2005, 08:44 AM   #4
Monkey's Avatar
just remember... an MIL is a part that gets rid of the CEL (check engine light). So you take the EGR off and you have to get an MIL to get rid of the CEL.
Old 02-22-2005, 11:22 AM   #5
Ponycarman's Avatar
Losing EGR also tends to make your car ping so you may have to go with a higher octane gas or the computer will back off the timing to compensate and you lose power.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 02-23-2005, 08:02 AM   #6
Send a message via Yahoo to 98GreenStallion
Im about to do an EGR delete as well. You will get a CEL. I dont think my CEL is wporking cause it hasnt come on once since the H/C/I swap.
http://images.cardomain.com/member_i.../402003_35.jpg
Mods: BV heads, cut and weld upper, fully ported lower, 216/225 cam, 1.73 RR's, 60mm TB, 19# injectors, new timing set, 25% UDP, CAI, SCT chip, PCV delete, EGR delete, MAC LT headers, O/R H-pipe, durablack cat-back...
www.rpm-mustangs.com
RDmotorsport
New dyno
193.8rwhp/238.9 rwtq
98GreenStallion is offline   Reply With Quote
Old 02-23-2005, 09:16 AM   #7
EGR uses MIL to take off CEL which hasn't come on for 98 GreenStallion sinde his H/C/I swap. Anyone who doesn't know what all this means needs to ask lol
Old 02-23-2005, 09:57 AM   #8
no.... MIL=malfuction indicator lamp
and MIL eliminator takes off the light
Old 02-23-2005, 09:47 PM   #9
OR_Red98's Avatar
Region: Oregon
Well I reckon I'll just have to stretch that bloody tube. Thanks for the replies guys.
Old 02-23-2005, 09:55 PM   #10
no problem.
Old 02-25-2005, 11:27 PM   #11
Region: New Mexico
Send a message via MSN to miwago
Post MIL eliminator for the EGR delete
Who makes them, or is there a schematic for them somewhere?
'98 T-5, 3.8 .. Ebay CAI, 25% 2 pulley UDP, 1.8 roller rockers 19 lph inj's, Xcal2, Reworked-ported upper intake, Full emissions delete, Dual 2.5" exhaust,2" drop Future mods:4.2 stroker kit, Locker diff w/3.73's, 18" Bullit wheels
miwago is offline   Reply With Quote
Old 02-26-2005, 03:16 PM   #12
RGR
Send a message via AIM to RGR
Hi Mike! Welcome!!!
Mike is a really innovative mechanic, we talked for over 3 hours
one night and he has some wild ideas, but is capable of executing them!
3.8 OHC anyone?
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 02-26-2005, 03:44 PM   #13
OR_Red98's Avatar
Region: Oregon
3.8 OHC anyone?
Hmmm that would be cool, especially if it were DOHC but that's a pipe dream.
Old 02-26-2005, 04:02 PM   #14
RGR
DOHC is but OHC is technically feasible, Mike is looking into it.
Hey, if I had the money I have the resources here in my town to do basically
anything, including DOHC on this engine. Plus, it's only 1 hour from Indianapolis.
Old 02-26-2005, 10:15 PM   #15
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
overhead cam... Sign me up.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 02-27-2005, 02:11 AM   #16
Region: New Mexico
Hey RGR .. nice to see you again.
I like this board alot more than the one RGR and I used to be on. His experience and expertise is immediately obvious in his posts and in talking to him on the phone.
As RGR said, I am looking into making an SOHC setup, with the existing heads. The minor kinks are timing belt routing, and repositioning the waterpump, but some of that is simplified with the ability to remove the timing chain cover. The initial benefits .. lower valvespring tensions, reduced recipricating mass, reduced parasitic horsepower loss and far less valvetrain float at higher RPM's. I still have a great deal of research to do, but I know it is possible. I think the research was NOT done before because the 3.8 has been overlooked in the "purpose built" aftermarket sector, I.E. .. not financially feasible.
As for the DOHC setup, .. I'm sorry, but it would require a completely new head, and it would be far too costly.
Anyway, I am, as RGR said, Mike. Good to be here.
Old 02-27-2005, 08:10 AM   #17
slvr2000stang's Avatar
Originally Posted by RGR
Hi Mike! Welcome!!!
It is nice to have a variety of site availble to visit.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
How did this happen in the US? oaktonarcher The Bar 29 04-28-2010 06:17 PM
Things that could happen when you get old Herbstang The Bar 1 07-02-2008 12:19 PM
Can or Will Happen? Seph The Bar 176 03-20-2006 08:58 PM
08:00 PM
