Maf ? - Mustang Evolution
Old 02-22-2005, 01:45 PM   #1
FloMasta24's Avatar
Send a message via AIM to FloMasta24
Maf ?
I think I may need to buy an new MAF because I cleaned it and everything else including the throttle body and it still does somewhat of a stutter thing. Does anybody know whethere or not an auto parts store would carry it or have to get it a a dealership?and the price?
1998 3.8L Mods: CAI, Flowmaster dual exhaust with H-pipe, Black Cobra Style headlights, Racer's Choice short shifter -SOLD!
Now cruising in an '03 Nissan Spec V w/ intake and exhaust-hell yeh
Originally Posted by Seph
vday is like an srt4, at first it sounds good and in the long run it sucks
FloMasta24 is offline   Reply With Quote
Old 02-22-2005, 02:11 PM   #2
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
It most likely is not your MAF to begin with. Tehre are tons of other parts it could be...
Clogged injectors, bad plug or wire, dirty air filter, something wrong with your trans....
What exactally are your symptoms?
Rellik is offline   Reply With Quote
Old 02-22-2005, 08:40 PM   #3
FloMasta24's Avatar
sometimes it will stutter in mid acceleration no matter what RPM...it sends like a surge thro my whole car
Old 02-22-2005, 10:41 PM   #4
Replace your fuel filter see if that fixes it
Old 02-23-2005, 11:53 AM   #5
Monkey's Avatar
If you decide to replace your MAF (which it doesnt sound like that's the problem) then I would goto a junk yard and just pull one off one of their cars. Cheap and it will work.
Old 02-23-2005, 11:54 AM   #6
A MAF problem would constitute hesitation, stalling, or rough idle in all RPM's.
When was the last time you got some injector cleaner?
When was your last fuel filter replacement (thank you Brent)?
How many miles are on your fuel pump/car?
When was the last time you replaced your plugs/wires?
How dirty is your air filter?
See all the questions I can come up with?
Old 02-23-2005, 10:00 PM   #7
FloMasta24's Avatar
Alright thanks I know I could use a couple of those so Ill try them.
Old 02-23-2005, 10:05 PM   #8
5 speed? it may be your IAC/idle bypass valve its cylinder shaped and sits behind the throttle body on the upper intake ( on 99+ ) mine went out and idle was a biotch if it idled at all (may just die) so go replace that sucker.
Old 02-24-2005, 06:07 PM   #9
FloMasta24's Avatar
yeh its a 5 speed but a 98 so dont know where that would be...unless its on the valve cover
MAF bsmith782 1996-2004 Mustang GT 12 01-30-2007 04:07 PM
90MM MAF DarkShadow Mustang Parts for Sale and Wanted 9 11-29-2006 10:11 PM
MAF gone bad powerhungry966 Pre-2005 V6 Mustang 5 01-24-2006 12:07 PM
do i need an aftermarket MAF? I_luv_HP&trq Pre-2005 V6 Mustang 8 08-02-2005 08:14 PM
is this what your MAF looks like.... project232 Pre-2005 V6 Mustang 13 02-23-2005 03:47 PM
08:17 AM
