Transmission problem.... I think...HELP! - Mustang Evolution
Old 06-03-2009, 05:33 PM   #1
Region: Hawaii
Hi guys. I have a 5 speed 2006 4.0L V6 Mustang. I just got back home from Cali a week ago, and i started noticeing that when I shift into 3rd, 4th, 5th gear while im driving normally it takes a second for the car to engage. The rpms will go all the way up to around 5200 rpms till it catches and the rpms gradually go back to normal. Also, there are no funny noises under the hood and when the gears catch, the doesnt jolt or anything. what can it be, it is starting to get annoying. Thanks guys for the help.
BbV06Stang is offline   Reply With Quote
Old 06-03-2009, 07:45 PM   #2
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Re: Transmission problem.... I think...HELP!
alrighty, you said 5 speed, is it stick or auto? (do the 06's have a 5 speed auto?) if it was a stick id say your clutch is slipping... if its an auto... i have no idea what it would do that in only those 3 gears cept that you would want to check your trans fluid first.
thats all i can really say from my experience...
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 06-04-2009, 01:37 AM   #3
OsirisGuy's Avatar
I'm assuming it is a standard transmission. Sounds like the clutch is going or went rather.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 06-04-2009, 06:52 AM   #4
SaleenFiend's Avatar
Yea, I would say the clutch is slipping also.
Old 06-04-2009, 07:29 AM   #5
if the clutch is out and the shifter is in gear and the rpms go up but the car doesnt move then the clutch isnt grabbing either because its worn or the clutch isnt adjusted right and its not coming back out all the way
Old 06-04-2009, 11:16 PM   #6
Region: Hawaii
Its a standard. Thanks guys, i wanted to get some mustang pro's opinion before i started messing around down there. lol thanks again.
Old 06-05-2009, 01:14 AM   #7
MonteCitan's Avatar
in first and second where does the clutch grab? Just off the floor? or do you have to let the clutch pedal most of the way out?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-05-2009, 03:43 PM   #8
Region: Hawaii
Yes it engages just of the floor.
Old 06-07-2009, 10:59 PM   #9
ck too see if the fluid for the slave cylider is low
colorado pony is offline   Reply With Quote
New transmission V6stang_007 Pre-2005 V6 Mustang 12 11-25-2009 04:10 PM
transmission problem..2006 v6 jackwhite General Mustang Discussion 4 05-21-2009 04:21 PM
Transmission fit problem claytonbeaver Classic Mustangs 2 05-05-2009 09:17 AM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
12:07 PM
