FRPP Lowering Springs - G Springs - Mustang Evolution
Old 02-22-2005, 08:38 PM   #1
Stangthang's Avatar
I have 02 convertable and am looking for a 1.25 -1.5 inch drop, any other vert owners use these or somthing else?
Stangthang is offline   Reply With Quote
Old 02-22-2005, 08:39 PM   #2
im not sure what vert owners use let me look into it.
Old 02-22-2005, 08:40 PM   #3
they are 210 dollars for that price i suggest h&r springs or eibachs
Old 02-22-2005, 08:49 PM   #4
Stangthang's Avatar
I wondered if a vert dropped different than the coupe
Also I cant seem to find the drop I want in h&r or eibachs (1.25 -1.5) im worried 1.5 will be too low, I dont want to buy c/c plates.
I do have a set of mach1 tokicos to pair up with the springs.
Old 02-22-2005, 09:02 PM   #5
yeah with a 1.5 drop you will need c/c plates, and the mach 1 yokicos will be fine with the drop you want
this is what i reccomend
http://www.stangsuspension.com/store...p?idproduct=61
Old 02-23-2005, 10:43 AM   #6
fastmustangs1's Avatar
Question
Well everbody is different. Some run Eibach, H&R Ford Racing it is up to you which springs you want to go with.
Matt
fastmustangs1 is offline   Reply With Quote
Old 02-23-2005, 03:05 PM   #7
Stangthang's Avatar
I think I will cut the rear dead coil and use the c-springs that I have, at least for now see what that looks like.
Thanks
Old 02-23-2005, 03:13 PM   #8
Send a message via AIM to charkelly9
i have an 03 vert. and im looking into springs but i really dont want a drop so drastic as 1.5in.. im thinking just .75 in.. bc i already bottomed out hard enough to break the lil plastic guard that suppose to protect the underbody in the front. however.. with a new spring .75in. drop and other suspension upgrades would CC plates be a necessity.. do they help suspension that much?
charkelly9 is offline   Reply With Quote
Old 02-23-2005, 03:21 PM   #9
Stangthang's Avatar
You should just use the c-springs thats about the drop you will get if you dont cut and use your isolators.]
And you wont need c/c plates, no problem
Ill sell you a brand new set still in the box if your interested
Old 02-23-2005, 03:57 PM   #10
C springs will give you 1.2-1.3 all around, having a convertable you may not need to cut the rear springs (but im sure you will the weight is not that much more ) so i would install them with out cutting and then cut a half coil and see hwo that works... i doubt you will need more than half a coil on the backs cut.
Best lowering springs????? Camaro Eater Pre-2005 V6 Mustang 14 07-07-2010 04:22 PM
LOWERING SPRINGS CHILE10_STANG Pre-2005 V6 Mustang 17 05-02-2010 09:00 AM
Lowering Springs MRACING 2005-2010 Mustang GT 1 01-11-2010 03:11 PM
Lowering Springs greenpony02 1996-2004 Mustang GT 50 05-28-2008 01:40 PM
Lowering springs Kryptonite 1996-2004 Mustang GT 3 11-27-2006 02:29 PM
10:03 AM
